  1. Member golfnut's Avatar
    Sep 2003
    Would like to purchase a high resolution, high quality scanner for scanning CD/DVD inserts and covers. Recommendations would be greatly appreciated. Must be compatible with Windows XP. Thank you for your help and reply.
  2. I have always been quite impressed with the Umax range of scanners.
  3. Member The village idiot's Avatar
    Apr 2002
    Adrift among the STUPID
    If it is just for scanning disks and covers, any run of the mill scanner will do. If you scan them at high resolution, you will get bad looking images because the printing is not continuous. The printing used is set to have the different colors spaced between each other, and is normally very low resolution like 100 line per inch. Any scanner can do that. So just get a "name brand" scanner in the $50 range. Or if you really want, you can get a really expensive one in the $400 range, but it will look the same when you are done.
    If you want to pay for a scanner that has some features, find one that will do de-screening on the scans, so that you won't have the prolem with scanning printed "objects" likes books, and cover, and disks.
    Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
  4. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    Ive got a canon LIDE 30 which is really nice. it was 99$ when i got it 79 now and does everything i ask it to do.
    there is also a newer one LIDE 50 just looks a bit better on the specs.
    hope this helps some.
  5. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    We use Epson 1670s at work and they seem to do well enough. Most of the things we scan get blown up to over 400% their original size and do pretty well at 600dpi.
  6. Member golfnut's Avatar
    Sep 2003
    My sincere thanks to all those who replied and helped me. Thank you.
