I am a newbie trying to make back-up DVD's. I tried every software out there, but no matter what I do I get coasters. My roomate has been making his own back-ups for some time, so I had him use my external burner on his computer. Using the same burner and media he was successful his first try. I believe there must be a configuration problem with my computer but I cannot determine what. Every program I used to shrink/burn gave me the same error ("There may be a problem with the medium; error burning DVD") and stopped burning at the same spot (25% into the process). Can anyone offer any suggestions?
Results 1 to 10 of 10
I suggest you tell us -Originally Posted by smot
- specs of your pc
- model of burner
- type of media
- detailed processes you've been using to do your backups- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Get your roommate to show you how .
You aren't holding your mouth right. You have to stick your tongue out a
little bit on the side , and grunt once in a while . -
one thing i would try, is when you are burning, make sure you close everything that you dont need running. hit ctrl-alt-del and close things u dont need. disable anti virus programs, disconnect from the internet, etc
specs and procedures ive been using
NEC 4X BURNER 2.0 USB external
FUJITSU LIFEBOOK C SERIES; WINDOWS XP HOME (BOUGHT 2002--BRAND NEW TO MARKET)
1ST TRY: DVD DECRYPTER; DVD2ONE, COPY TO DVD
2ND TRY: DVD DECRYPTER; DVD SHRINK; COPY TO DVD
3RD TRY: DVD DECRYPTER; DVD2ONE; PINNACLE CD/DVD INSTANTCOPY
4TH TRY: DVDXCOPY XPRESS (I LIKE THIS BEST EVEN THOUGH NOTHING WORKS)
I used ACCU, BeAll, and HQ media. Everytime it burns it stops about 3/4 of the way through -
LIFEBOOK C1020...................................lists USB 1.1
LIFEBOOK C1110 / LIFEBOOK C1110D..lists USB 2.0
Which one do you have.
The transfer rate for USB V1.1 is about 12Mbps, where USB V2.0 is like 480Mbps. That's a big difference.
If you have USB V1.1 then you might haft to burn at 1x. And, like stated above, turn everything else off.
Hope this helps.
Good luck. -
Try DVDShrink/IMG Tools/Nero
I've been having major problems with the new DVDDecryptor, it's flakier than shit when burning (doesn't seem to support underrun correctly).To Be, Or, Not To Be, That, Is The Gazorgan Plan -
im not sure what C series it is but it states it burns at .7x when i use copy2dvd and pinnacle instantcopy. i tried to change the rate but it still only burns at .7x which i think might be why it stops 3/4 the way through, let me know your thoughts
.7X is a good indication you have USB V1.1. It's too bad you don't have a Firewire burner, I see (in the review) your ltop has a connector.
Check "Burn Proof" setting and turn it on if possible.
All I can think of is to try a different burning program. Like the one that came with your burner. What was it?
DVD movies are easy to burn. I have my authorizing program create a 'dvd folder' on hdd of my finished project. I try my project out with PowerDVD (from that folder) to make sure I'm happy with the results. I then start my burning software (RecordNow DX), select my DVD burner, choose "Data Disk" and drag in my 'VIDEO_TS' folder. Choose "Track at Once Closed", then burn. I'm not having any trouble using this routine. I'm also using DVD-RWs for my first run. I check out my project on TV and if I'm still happy I'll make the finished burn with an DVD-R disk. Erase my RW disk, project finished.
Good luck.
I just had a brain storm! By you using a ltop it probably has every power down option enabled. If you were to 'time' that 25% and compare that time to the settings you're running for power down - power saving mode I'd say they match up. Right click on the desktop, choose Properties, then Screen Saver then Power, I believe you will see what I'm talking about. When you burn a disk you will need to set your power savings mode to 'Never' and disable all that other stuff. (and be running on A/C).
'Presentation' would be a good setting and turn of Hibernation.
Good luck. -
Originally Posted by FOO
Best TV brand for DLNA?
By trevytrev in forum Video Streaming DownloadingReplies: 2Last Post: 19th Nov 2014, 10:00 -
Is VUESCAPE an ok brand?
By yoda313 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 10th May 2009, 20:13 -
Brand new member
By DavidCWM in forum Off topicReplies: 13Last Post: 9th Feb 2008, 02:02 -
Best brand of laptop?
By Tbag in forum ComputerReplies: 16Last Post: 7th Feb 2008, 23:59 -
What brand DVD-R is best for the G5?
By Rich W in forum MacReplies: 5Last Post: 23rd May 2007, 20:08
