when I trim an avi movie in QT pro it becomes a very poor quality
Any ideas on what i'm doing wrong
What avi plugin (codec) are you using?
What format are the avi files encoded in?
I am trying to trim the opening/closing credits off some Japanese anime TV shows (RahXephon) - because only 1-through-24 will fit on a DVD. If I trim the "redundant" parts - I may be able to fit all 26 episodes on one DVD-R.
My first attempt, with the Divx 5.1beta2 codec, seemed to reduce the quality -slightly- after trimming. And the Quicktime information window stated the video was "XviD" => which may be the problem. Divx trying to write a non-"Divx" file.
Just downloaded the 3ivx codec, and the Quciktime info window states the video is "3ivx D4 4.0.4, 640x480, millions".
After the trim, and saving as a "yadayada.mov" file - the quality appears identical to the original.
Mike
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 17:01 -
Teen falls in open manhole while texting
By freebird73717 in forum Off topicReplies: 19Last Post: 13th Sep 2009, 17:44 -
Do Movie Maker or Virtualdub re-encode DV-AVI when saving? Quality concern?
By sdineen in forum Newbie / General discussionsReplies: 9Last Post: 18th Jul 2009, 21:47 -
Cannot get trimmed a DV-AVI movie in MS Movie Maker
By askmaxim in forum EditingReplies: 0Last Post: 30th Dec 2008, 05:44 -
Removing Niagara Falls background noise
By MedievalMan in forum AudioReplies: 4Last Post: 28th Sep 2007, 19:21
