Hi all:
I am having big problems using toolame with tmpgenc - when encoding svcd in tmpgenc with toolame specified as the MPEGII audio encoder, I get the message "the external encoder was not run properly".
I have also tried to run toolame from the command prompt in XP and I get the message:
rsx not found, dpmi not supported by emx
Can anyone tell me what is causing this?
Steve
Results 1 to 10 of 10
Are you aware of this.
The version of tooLAME 02l (2-Mar-2003) does not generates audio files compatible with TMPGEnc plus. Until tooLAME and/or TMPGEnc fix the problem, continue using tooLAME up to version 02k. -
Originally Posted by Craig Tucker
Well thats up to you, you can either use TMPG for audio encoding or lame providing it is version 02k or before.
Thanks for you time Craig,
I'll just stick with tmpge then.
ps shame about England with the 16 man thing over here in the Union. -
Will be interesting to see what will happen.Originally Posted by scottb721
Actually, I have tried a number of versions - i, j, k and l and all of them have produced the same error.
Might it be an incompatibility with XP?
Cheers
Steve
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 07:57 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
TMPGEnc plus & ac3
By natty in forum Newbie / General discussionsReplies: 7Last Post: 11th Jan 2009, 09:01 -
Subs & Filters in Tmpgenc DSC
By marioval in forum Authoring (DVD)Replies: 5Last Post: 24th Apr 2008, 10:34
