Hi all
I've been using the new dvd shrink for about a week now. & its been ok well its been brillent i think the quality is so much better when doin the deep analysis before hand.
i've just turn my pc on this morning to back up another film, opened dvd shrink got every thing set the way i wanted it & when i hit the button to back the film up, the area for deep anaylsis was grayed out & it will not let me select it........
any ideas what i can do to get this working again
thanks
watty252
Results 1 to 9 of 9
I had the same problem... until I realized it was a DVD that I had already done a deep analysis on, but never actually hit the 'back up' button. I'm guessing it saves the results from the deep analysis somewhere, so you don't need to do it again.
Thanks Vandakeg.....
That would make sencse as i alreday did i deep analysis for the film i wanted to back up -
Hi all.
DVD Shrink does indeed save the results of deep analysis.
The files are in a hidden folder situated at:
"C:\Documents and Settings\{username}\Application Data\DVD Shrink 3.0"
Even better, DVD Shrink saves the result of a partial deep analysis.
So it will start where you left off when you decide to complete (or continue) it. -
A lot of people get confused by this. Instead of greying out the button perhaps there should be a pop up explaining that analysis has allready been done.
Thanks. -
Originally Posted by prestoYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
Greetings,
For a Beta version, I find it is pretty stable. In fact, I had more problems with DVDxCopy Platinum commercial non beta release than DVD Shrink. It is why I decided that until they fix their faulty product, I shall use my combinaison of DVD Shrink, IMGTools and DVD Decrypter to copy my DVDs. It takes a little bit longer, but the results are better and I do not waste a DVD-R because the software crash during the writing.
Not to sounds to praise to much the author of DVD shrink, but I would pay for his product if it would not be free. I wish the next version will add a couple of functionalities like black screen instead of "still image". In spite of this, it is still the best.
Thank you -
Thats why its called "BETA"
Burning DVD Could not perform end of disk-at-once
By jasonkral in forum Authoring (DVD)Replies: 8Last Post: 13th Feb 2011, 23:05 -
Could not perform end of disc-at-once on dual layer dvd only
By Subhash in forum DVD & Blu-ray WritersReplies: 20Last Post: 25th May 2009, 13:09 -
Only First Session readable on DVD Player-- Deep Burner
By deepakOne in forum Authoring (DVD)Replies: 1Last Post: 27th Oct 2008, 02:13 -
Software for analysis CD/DVD
By grzegorz in forum Newbie / General discussionsReplies: 3Last Post: 21st Apr 2008, 20:14 -
DVDFab 4.0.2.0 Beta backup crashed Shrink - fixed(sort off)
By pchan in forum DVD RippingReplies: 1Last Post: 21st Dec 2007, 09:04
