Hello,
Thanks for all ya'lls help with capture and editing software to use with my new ADVC-100.
Most of what I am currently capturing and converting is music related so i will be converting and burning to DVD with PCM audio for those.
I will however be capturing and converting some TV programing soon as well(episodes of 24, Carnivale etc.) and would like to convert the captured audio to AC3 for burning to DVD. Of course for now it will just be stereo audio so 5.1 isn't necessary for now. What is a good, easy inexpensive app. for converting to AC3?
I noticed that nero lists DD AC-3 5.1 conversion as a future feature on NeroVision Express 2. Does it currently provide stereo AC-3 conversion?
Thanks for any suggestions.
Results 1 to 9 of 9
Beesweet? Don't know for sure, but take a look...
10110101100111012011 <- The bug Bill doesn't talk about. -
In the past I've heard people complain about BeSweet/ac3enc producing distorted audio and non-compliant streams under some conditions...does anyone know if this is still the case?Originally Posted by bugster
Good question.
I made the decision to purchase Sony [formerly Sonic Foundries] Vegas 4+DVD the bundle includes an ac3 encoder.
I had used besweet and followed the excellent guide provided by lordsmurf. The ac3 sound track played on my panasonic set top dvd player and failed to play on my portable koss, an oritron, and pioneer player.
I realized that if I am going to spend the time to produce a disc which I would like to share with friends and family, I need to acquire a reliable dolby licensed ac3 encoder.
You may wish to surf the net and see if a licensed dolby plug-in exists for your software. Surcode makes a two channel ac3 plug-in that works with Adobe Premier 6.0 and 6.5 for $150. DVDit Pro dvd authoring software contains an ac3 encoder and does a very nice job authoring dvds.
Regards
John -
I've thought about getting Vegas+DVD myself. Can anyone comment on the licensing? I'd hate to spend $500+ on something only to find out that it has some "product activation" spyware crap in it that is going to freak out and refuse to run every time I upgrade my hard drive or CPU, or reinstall the OS, like Windows XP does. Does it lock itself to the hardware in any way?
Sometimes, sometimes not.Originally Posted by Metaluna
I use it primarily. If it gives problems, then I use DVDit! PEWant my help? Ask here! (not via PM!)
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 19:26 -
Canopus ADVC-100 - noisey/grainy and scaling?
By Gibson's Squares in forum Capturing and VCRReplies: 4Last Post: 2nd Jun 2011, 15:41 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
Canopus ADVC-100 and PCI Firewire card
By spiderbaby in forum Capturing and VCRReplies: 12Last Post: 5th Mar 2008, 09:39 -
Canopus ADVC-100 outputs
By datman in forum Capturing and VCRReplies: 2Last Post: 7th May 2007, 19:24
