Is there a way? I think I want to use the Panasonic DV Codec instead. I hear it's better.
i would not say its better .. but you can disable the either one
uninstall any codec by using regsvr32 with the /u command line switch or
here is a really good tip for all of you -- to reg and unreg ANY dll and/or OCX codec or directshow filter .. do the following:
If anyone has problems registering dll or ocx files, here's an easy way to register/unregister the files in Windows 95, 98, NT/2000 and XP.
Copy/paste the REGEDIT4 text below into a notepad and save the file as register.reg. Then double-click this file to merge it with the registry (make a backup of your registery before altering it).
Then, by right-clicking on any .dll or .ocx file, the options to Register/Unregister should be available in the Explorer context menu.
REGEDIT4
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\dllfile\shell\ Register DLL\Command]
@="RegSvr32.exe \"%1\""
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\dllfile\shell\ Unregister DLL\Command]
@="RegSvr32.exe /u \"%1\""
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ocxfile\shell\ Register OCX\Command]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ocxfile\shell\ UnRegister OCX\Command]
@="RegSvr32.exe /u \"%1\"""Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I'm just having problems capturing in Virtualdub from a Canopus ADVC-100 device.
well -- the compression is done IN the ADVC , you cant change that codec ..
Shoot. Sorry. I have 2 topics in my head right now.
You're right, of course. There must be something wrong with my VirtualDub installation, as no codecs are being shown when trying to capture from ADVC-100 using VirtualDub.
And I also heard that opening/working with AVI files in VD that are captured from a DV source, the Panasonic yields "more consistent" results; said another way, I've read that some people have some problems with the Canopus codec.
I'm also going to try the Adaptec Codec. -
READ THIS
DV ... the compression is done at the source ,
not with the capture program ... you can install every DV codec known to man (girl, alien whatever) and it still would not change a thing ..
also virtualdub not the best for capturing DV (which is a transfer) .. you can even use windows own movie maker for the capture (transfer) part because as i said -- the compression is already done .
installing a different DV codec is only importaint when you either re-render a DV to something else (even a different DV codec) or edit it (sometimes)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Uninstalling or reinstalling nero
By b3cko in forum ComputerReplies: 3Last Post: 10th Jan 2008, 08:37 -
Uninstalling this utorrent program
By vipertongn in forum ComputerReplies: 7Last Post: 5th Aug 2007, 07:17 -
Should I install Canopus Codec?
By tranbuimd in forum Video ConversionReplies: 4Last Post: 26th Jun 2007, 18:01 -
Trouble uninstalling dvd43 - help
By NitroxAZ in forum Newbie / General discussionsReplies: 1Last Post: 18th Jun 2007, 22:43 -
no audio device after uninstalling antivirus?
By Rudyard in forum ComputerReplies: 4Last Post: 23rd May 2007, 21:19
