have heard somewhere that it is possible to erase/delete some fix text in a vcd.
i got some video already in vcd that have text in it( you know some person put his name in the right bottom corner or icon or put a title/web adress in top .....)
so my question , how can we delete this???
thanks for your time
As far as I know, you can't. If you extract the video and run it through a program like virtualdub you can mask a logo, but if it's burned into the video, you can't simply remove it.
thanks for reply.
what i have heard is that we can do something with tmpgenc.
you know how????
what about vdub, how can i mask ??
p.s was thinking it was possible to remoove , cause if it's a still image in a video(always at the same place ,) so with some soft , will be able to remove it.but i know it sounds weird. -
You can "mask" it with a logo removal filter for Virtualdub (see TOOLS section) but it will not erase it. What it does is use the surrrounding area to sort of blur it (as Redwudz said). You may prefer that or you may not.
There's a few types of filters, some better results than others, some a little trickier to do than others.
You can learn about them on Virtualdub's site or searches here in forums.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
thanks for your time ,
will check it .
will see if the result is better than right now
Need to erase text inside video
By snafubaby in forum Newbie / General discussionsReplies: 3Last Post: 5th Sep 2011, 21:18 -
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 08:54 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 10:38 -
Adding text over original text
By stixster in forum EditingReplies: 3Last Post: 17th Jun 2008, 05:14 -
C# code to save text from listbox to a text file -- SOLVED--
By freebird73717 in forum ProgrammingReplies: 2Last Post: 2nd Sep 2007, 15:50
