Ok I have the Scarface 25th Aniversary 2 Disc DVD, I used DVD Decrypter 3.1.6.0 to Decrypt it and then I used DVD 2One version 1.3.0
Then burned with Nero, Burned fine, DVD plays fine goes right to menu quality is great too, My problem is that when I go to screen selection the last four chapters and select one it stops the dvd?? Why didnt I get the whole thing?? What is wrong? Has this happened to anybody else?
Ok I forgot to add that I didnt burn all the VTS_ files, They would nt all fit on the disc, So I took out the last VTS files 4-5 vobs?
I looked at them in Power DVD and they where just logos from Macrovision and Some other? Do I need these files to have the DVD work ?? I burned with a media HP DVD +RW @ 2.4X my DVD burner is Sony. I will try 1x and see if that works? Thanks
