i used studio 7 to save a vcd mpeg1 & burned it to a cd using nero 551. everything during the burning process seemed to work fine, however, it won't play on my panasonic dvd c220 (carousel). now, the dvd player also doesn't play cd's that i've made, but it says it's vcd compatible. i've got 2 coasters now, and i'm on the verge of buying a more modern cd player. anyone have any suggestions?
bigjr123,
As reported by users, your Panasonic C220 doesn't accept CDR midia. Plays/works VCD but burned on CDRW midia only.
Take a eye on:
http://www.vcdhelp.com/dvdplayers.php?DVDname=panasonic&Search=Search&list=0
Bye
thanks for your reply. cdr as opposed to cdrw? so if i just use a cdrw disc, it should work? i'll try, if not, that's 3 coasters & i'm getting a new dvd player!
also, i put the cd-r disc in my pc dvd & tried to run it using windvd. it just flashed the menu i made for a second & then went back to the black screen. can this mean that i set up the menu wrong in nero? i set it for "infinite". thanks!
On 2001-10-09 10:42:58, lafamar wrote:
bigjr123,
Take a eye on:
Bye
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 18:57 -
Problem playing back JVC miniDV on Panasonic camera
By Ryuran333 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 3rd Feb 2010, 02:16 -
Pattern effect / recording or playing on Panasonic combo machine
By mdeange3 in forum Newbie / General discussionsReplies: 0Last Post: 1st Jul 2009, 17:43 -
Playing VCD on Computer or convert to DVD
By corumz in forum Authoring (VCD/SVCD)Replies: 3Last Post: 22nd Jun 2008, 06:35 -
Panasonic DVD SA-HT743 stopped playing Original DVDS
By chankya in forum DVD & Blu-ray PlayersReplies: 0Last Post: 23rd Dec 2007, 17:38
