Hello.
How can I make a XSVCD? I have a .d2v and a .ac3 file on my HDD. I can use they with TMPGEnc 2.00. But what settings do I need to charge? For example: what video & audio bitrate should i select? And what's the difference between Stereo, Dual Channel and Joint Channel? What option should i check for creating a Dolby Digital AC3 sound?
Thanks very much.
Where it says configure on the bottom corner (at least in my version, I haven't tryed 2.0) and load the SVCD template for your region. (ie. NTSC, PAL). See the coloum on the side of this window, where it says SVCD, click that for more info. Or XSVCD, higher quality, but can fit less on a cd.
Make samples ?
By yabbah in forum Newbie / General discussionsReplies: 1Last Post: 27th Dec 2009, 06:41 -
How can I make SD look like HD?
By Nuke Shower in forum EditingReplies: 4Last Post: 29th Jul 2008, 13:53 -
anyone knows how to make this (example)
By pike8 in forum EditingReplies: 6Last Post: 18th Feb 2008, 16:21 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 06:10 -
I want to make a DVD..
By Nyntendou in forum Authoring (DVD)Replies: 3Last Post: 26th Oct 2007, 11:33
