The subject says it all. Any ideas what to try?
I paid extra for the 4x for the time savings. I want to get it.
TIA.
Greg
I should've mentioned that I'm burning an image created by ImgTool0.90b with DVD Decrypter.
The image is on a seperate HD from the OS and Apps.
Athlon 2600 with 1GB ram. -
What firmware are you using?2.16 is the latest.
Make sure DMA is enabled on all your drives and use the latest DVDDecrypter. -
I can't see how to get that info. Where should I look?Originally Posted by MOVIEGEEK
Thanks,
Greg -
Go to Device Manager and select your Optorite->Properties->Settings.
Here's the firmware page: www.optorite.com/firmware.htm -
Device Manager->Optorite->Properties doesn't tell me anything about firmware. I'm using WinXP. The only driver mentioned is a MS driver from 2001.
I already upgraded to the firmware that enables all 8MB of cache. -
Updated firmware and changed the ATA wiring so that instead of the DVD burner connecting to a PCI card IDE adapter, it connects to a motherboard IDE adapter.
Now burning a 4+x!
Yeah!
Where Are these Ritek CD-Rs Made???
By NBK2 in forum MediaReplies: 19Last Post: 19th Aug 2010, 14:32 -
Questions about Samsung SH-203 SATA DVD burner
By Phantom Of The Opera in forum DVD & Blu-ray WritersReplies: 5Last Post: 21st Nov 2007, 22:07 -
Ritek: NEVER EVER AGAIN
By mrlar2 in forum MediaReplies: 50Last Post: 15th Aug 2007, 04:13 -
Ritek CD-R White Printable Quality
By mmbetz in forum Newbie / General discussionsReplies: 4Last Post: 18th Jul 2007, 21:32 -
Ritek Ridata DVD-R 4X G04 where or better?
By Illicious in forum MediaReplies: 8Last Post: 15th May 2007, 11:41
