I just downloaded 9a, and am having problems converting an iMovie/iDVD VOB. Since an iMovie/iDVD-based VOB uses LPCM, I'd like to create a new MPG/VOB, using the original video but compressing the audio (doing this so a PrismIQ will be able to open the file - it can't cope with LPCM).
I choose the DVD hi-bitrate, change the video setting to "Passthrough (ffmpeg)", disable "Author as DVD" (since I just want the VOB), and click encode. I wind up with a file that looks to be about the right size, but I get the following when I try to open it with VLC .6.2:
"main: no suitable decoder module for fourcc `mpg1'."
Any suggestions? ffmpegx is the only tool I've found so far that can deal with the LPCM (since creating a SVCD works - but it takes 10x the length of the original, on a dual G5-2ghz!).
Thanks!
mbourgonGuest
mbourgonGuest
*bump* This is on a G5 running Panther, if that helps.
Converting TS to MKV - video is shaky and seek doesn't work
By Scorpick in forum Video ConversionReplies: 11Last Post: 5th Mar 2012, 19:11 -
Codecs and non-video aspect ratio? Why doesn't it always work?
By Taapo in forum Video ConversionReplies: 10Last Post: 7th Jul 2011, 20:40 -
Audio in my video doesn't work on all computers
By MattMedia in forum AudioReplies: 4Last Post: 26th Jan 2011, 11:40 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 06:58 -
Camera video doesn't work in frame after editing
By synlupri in forum Newbie / General discussionsReplies: 2Last Post: 14th Dec 2007, 00:35
