I have Vegas 4.0 and I want to add a timecode to the finished movie. In Vegas, the timecode only applies to events though, not the whole movie. So when the next scene begins, the timecode resets to 0:00.
Anyone know how I can get around this? Maybe a virtualdub filter? I did a quick internet search and didn't come up with anything.
apply the time code filter to the video bus ...
control shift B
you will see a new video track below a thick line -- that is your video bus
click the "video output FX" icon to he right of the word VIDEO on this track and apply the timecode filter setting you want
OR
TOOLS -> VIDEO -> VIDEO OUTPUT FX"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
you can apply ANY effect to filter to an event , part of an event , a complete or partial track , a time line , a media asset , to the preview window only , to the output only or to a single frame or in some cases - to the effect only ..
most of the above fully keyframe-able also"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Adding timecode data to a VP8 video at encode-time
By ilya.lissoboi in forum ProgrammingReplies: 0Last Post: 29th Apr 2011, 05:43 -
Vegas Pro 9 get timecode from AVCHD
By flamadiddle in forum EditingReplies: 12Last Post: 6th Jan 2010, 15:40 -
Sony Vegas Pro 8 - Adding VideoFX to many video clips at once.
By jnaizer in forum EditingReplies: 2Last Post: 30th Dec 2008, 20:28 -
sony vegas 7.0 keyframe adding
By m baqar in forum Authoring (DVD)Replies: 9Last Post: 20th Oct 2008, 07:36 -
Vegas adding video overlays using chroma key
By SearchQuality in forum EditingReplies: 12Last Post: 14th Dec 2007, 17:12
