Hi sorry about my spelling im from sweden.
So, when i convert from divx/ xvid whit Tmpgenc, the sound dissapear. This hasent been a problem before but now there is no sound.
I use ACE mega codec pack
I dont always use vituraldub to save wav, i just convert and that has till now been great...
but even when i save wav the sound is gone.......
please help me
Sebastian
Results 1 to 11 of 11
/ Sebastian
Probably a stupid question but I'll ask anyway...in tmpgenc, do you use the extracted wav file as the audio source not the original audio from the file?
I have tryed to use only the avi file, and i have tryed to make a wav file of the sound whit vituraldub...
nothing works/ Sebastian -
But my question was, when you get to the second screen of tmpgenc and it asks you for audio and video, do you use the avi for the video source and the wav for the audio source? I ask because I remember helping someone who extracted the audio but forgot to include it in the process.
Hi....
yes i use the wav for audio and the avi for video....
but now i tried VirtualdubMOD whit full compression and the wav i get there is much larger than the once i got erlier....
i think it works now.../ Sebastian -
To the author of VirtualDub: When a user selects Audio -> Direct Stream Copy Save WAV, Please, somehow make the unaware aware of that the output is not a wav file, but the audio track in whatever shape it came in (with wav headers). I can't count the # of posts where people claims to have converted the audio to wav, when in fact they have just demuxed the audio track from the AVI...
/Mats -
Hi mats
I have learn that now.. now i use VirtualdubMOD and there i chose Steams --> Steam list --> Rightclick on the file --> full compression mode.... then i get a much larger wav file.
Is this correct?
Tackar för hjälpen annars..../ Sebastian -
Yes, that's correct, even if I tend to do a direct stream copy, and then convert to wav from whatever format the audio is encoded as, with a dedicated tool.
/Mats
PS! Det var så lite så!DS
What do u mean? shall i save wav and then convert it to wav??? How???
and why???/ Sebastian -
By no means! If you get a file that's 'round 1 GB for your regular movie, it's probably OK.
The thing is, that if you select direct stream copy under Audio, and then save wav, you're not getting a wav, even if VirtualDub adds a ".wav" extension. It's still MP3 or AC3 or whatever audio format is in the AVI, and has to be properly renamed with the correct extension, and converted to wav with the correct tool.
This can be done in VirtualDub too, by setting Audio -> Full Processing, and then No compression under "Compression..." if VirtualDub likes the audio track in the AVI.
/Mats
ffmpegX Convert but no sound
By Ma_Long in forum ffmpegX general discussionReplies: 17Last Post: 7th Jan 2012, 07:42 -
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 14:54 -
No sound when I convert
By gkp in forum ffmpegX general discussionReplies: 8Last Post: 8th Sep 2009, 04:38 -
No sound on certain codec. Can I convert?
By ufcdanny in forum Video ConversionReplies: 3Last Post: 27th Jul 2008, 07:55 -
How to convert sound?
By Ran_Da_Man in forum Video ConversionReplies: 3Last Post: 19th May 2007, 13:50
