    Oct 2003
    Manchester UK
    Can anyone out there help me to backup my Beatles anthology Dvds, paid for !, when I try to copy them with usually succesfull methods ie dvd decrypter, dvd2one,clone dvd to burn, I GET NO AUDIO ?, whats going wrong, or is there other software out there that will help.
    Thanks all
    cookcroft
  2. you could try dvdshrink
    Not bothered by small problems...
    Spend a night alone with a mosquito
  3. Member Devanshu's Avatar
    May 2003
    Well, first rip to vobs using dvddecrypter. Then use something like dvd2avi to extract the wav file and the d2v, then encode, put it through a dvd authoring program, and burn away.
  4. I bet you are stripping the 1st audio track. I had this problem because my dvd player wouldnt play back the dts or pcm audio track, cant rememebr which it was now.
    Basically you need to re-order your audio streams in the ifo with ifoedit
