hi..
i've been burning a few dvds lately...
and i was wondering if there is any chance that i can damage my hard drive if I author o copy dvds frecuentely?
(I mean it by the large amount of data that dvd copy or authoring need)
Increase knowledge, increase sorrow.
Why would you think that it would damage your HD? 4.7Gbytes of data is not all that much.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
I've heard of this risk before and this is only a suggestion. I haven't seen any evidence of this. Doing something, anything on the computer is always a risk no matter what program or app you are using. This depends on your computer.Originally Posted by stk
The rule of thumb, if you have something installed not as default in Windows, such as a non-microsoft driver, an illegal codec or whatever installed not as digitally signed there is always a greater risk of a crash and become unworkable.
Some computers can be ok and not affected, the risk is always there.
If you done something stupid, not normal, such as not in order of app version, for example going back to an earlier release from the later version then it can mean big trouble.
This happened to me going from NAV2002 back to NAV2001 and this damaged the network/Internet settings and I have to clean re-install the hard drive. Just common sense go to the later version always.
Unpluging the power of the computer when processing is another stupid act as this is very risky.
The hard drive you using and this depends what you've got, how old is it, what make? I think the DVD copy would use the CPU more than the hard drive.
Can your computer cope with the work? Does your com freeze or crash? Again, this depends on what you've got?
You should defrag the drive every now and then.
Exact Copy of DVD made in Poland from Hard Drive of LG recorder
By dubronidog in forum MacReplies: 5Last Post: 18th Nov 2010, 10:14 -
How to copy "DICOM" CDs to hard drive then run from hard drive?
By JohnnyBob in forum Newbie / General discussionsReplies: 1Last Post: 25th Apr 2010, 18:18 -
Want to copy a DVD to external Hard Drive
By bwm258 in forum DVD RippingReplies: 9Last Post: 29th Jul 2009, 01:22 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 18:29 -
Copy/Paste DVD to hard drive?
By jason in forum Newbie / General discussionsReplies: 3Last Post: 23rd Feb 2008, 15:35
