I converted an .AVI with .ac3 audio to mpeg-1 (for vcd). I extracted audio first using virtdub, saved as .WAV, then renamed it to .ac3. Loaded the file into HeadAC3he 0.23 and converted it to 44100 khz PCM .WAV. Loaded the video and audio into TMPGEnc 2.5, encoded fine....plays fine on my pc....burned it to cd-rw, tried it in my DVD player, and the audio is choppy from the start. I had just made another vcd earlier that didn't use AC3 in the source, and it plays great on my dvd player, so what could the prob be? Any ideas? Thx!
PS.... the original source file is also XVID.....
Problem solved.....I was using the "fit on one cd" template I created in TMPGEnc, and then using the "auto setting". This auto setting set the bitrate to over 1700, thus too high for a vcd. When I lowered the bitrate to 1150, it works fine on my standalone. The audio is fine now. Thx, Soapy.
Multiavchd used & audio choppy
By jbitakis in forum Authoring (Blu-ray)Replies: 9Last Post: 2nd Dec 2011, 20:38 -
Choppy/ out of sync audio from homevideo to DVD
By dwilson in forum Authoring (DVD)Replies: 1Last Post: 11th Mar 2009, 22:53 -
Fast/Choppy Audio on Divx
By bassmaniu in forum AudioReplies: 3Last Post: 24th Jan 2008, 12:42 -
TS audio playback is choppy
By autumnwillow in forum Newbie / General discussionsReplies: 5Last Post: 12th Nov 2007, 09:14 -
Choppy video when enabling audio playback
By Xytrasx in forum Capturing and VCRReplies: 1Last Post: 3rd Aug 2007, 06:01
