Hi.
Could somebody familiar with DVD-lab explain me please what it is all about ("auto action" in "button link" tab) and what should I expect from such a function?
DVD-lab's help file didn't help.
I believe the auto action function is used to perform an action upon selecting a button, rather than selecting a button and clicking on it.
for example, having a button that once you select it, it automatically takes you to another menu, rather than selecting and then pressing enter.
this can be useful if you're making switched menus - lets say you have two movies, and one large graphic representing the first movie. when you go to a button that says "movie #2", you force the action which switches you to another menu with a large graphic for the second movie.
take a look at the mediachance website, there is a tutorial about switched menus.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Ok. Thanks "housebig".
I just had to use keyboard to move around menu buttons to see auto-action button responding. With the use of mouse it is impossible.
echo cancellation, auto volume, auto gain
By pror0ck in forum AudioReplies: 1Last Post: 10th Sep 2011, 06:01 -
PowerDirector auto-transition? auto-audio fade?
By yic17 in forum EditingReplies: 1Last Post: 16th Mar 2011, 14:59 -
Media Player Classic: Auto Zoom: Auto Fit logic
By DRP in forum Software PlayingReplies: 0Last Post: 29th Apr 2010, 08:59 -
Authoring an auto play DVD or editing an exsisting ONE to auto play
By theewizard in forum Authoring (DVD)Replies: 22Last Post: 16th Mar 2008, 11:06 -
Custom DVD Action
By marioval in forum Authoring (DVD)Replies: 7Last Post: 11th Jan 2008, 09:05
