I am trying to encode a AVI file (VIDEO: mpeg-2, size: 720x480, 29.970 fps, 7500 kbps. AUDIO: ac3, 48000Hz, 192 kbps.) to SVCD using the mplayer decoder (Quicktime errors out when reading the file, but mplayer works).
The resulting info is:
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
Tue Oct 28 12:09:52 CST 2003
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
**ERROR: [yuvscaler] Could'nt read YUV4MPEG header!
**ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
I am in Panther (10.3) - any thoughts?
Results 1 to 11 of 11
sal002Guest
sal002Guest
Not sure what other information there is. That was a cut & paste from the whole information portion of the process window. There was nothing else.
I suspect some of the fmpegX binaries need to be recompiled for Panther Some, like mpeg2enc, don't appear to have been compiled on Panther.
sal002Guest
Well, here are the steps I took and now everything seems fine. I really don't think any of these solved the problem (except maybe #4), but things work nicely.
1. Copied the mplayer from the latest MplayerOSX (from a few days ago) to a set directory (this was copied from within the mplayer.app within the MPlayerOSX.app file).
2. Downloaded the binaries from MplayerOSX project "for Panther".
3. Re-ran the engine installer using these new binaries (and the old mpeg2enc).
4. Installed the Mpeg2 codec for Quicktime.
Now, the encoding works - but I now make sure to select "Use Quicktime for decoding"
sal002Guest
I am using the SVCD preset, btw.
By the way, if you select "Decode with Quicktime", the said binaries are not used (as Quicktime is used instead to decode, and it will indeed require the mpeg-2 player component to decode mpeg-2).
peterhhGuest
same occures to me when trying to convert .mov files into mpeg2 for svcd. ( different .mov files and different tries )
video: size 480x576 , 2539 kbps, audioī: mpeg 2 44100hz, 224 kbps
using mpeg2enc
macOs X 10.3. panther
result info is:
info : ( yuvscaler ) couldnīt read frame header: bad header magic!
ERROR: (yuvscaler) coudnīt read frame number 43871
the number of teh not readed frame differs from try to try
peter
bozo99Guest
**ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!'
I had the same problems (10.3) altough I did a clean install of ffmpegx and binaries.
After restarting these problems disappeared.
sal002Guest
Well, after it is done with this encoding (12 more hours), I'll put back the old binaries recommended and try it again with the test clip. All I know is the test clip came out perfect with the above combination - but, like you said, it used Quicktime to do the decoding. So, riight now all is well and will go back to the required mplayer and mencoder.
Off topic - this is sooooo much faster than forty-two. 12 hours into encoding and I am 50% complete - forty-two told me that it would take 79 hours.
peterhhGuest
i donīt know how often i rebooted. but things didnīt change.
peter
Originally Posted by bozo99
Error message - Could'nt read YUV4MPEG header
By LoafingOaf in forum ffmpegX general discussionReplies: 1Last Post: 29th May 2010, 00:56 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 18:10 -
source filter error (Error=80040241) when playing HR Avi
By mwm in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 10:03 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 11:41
