I have been using Nero Vision Express to transcode and burn Avi files to DVD, but the audio goes out of sync. Does anyone know how to put back in sync.
Lulu
I don't think anyone here will recommend using Nero to encode your avis.
Nero is a generally a good, versatile tool for burning, but the video encoder on it is not really up to much.
You'll get much better results if you use a dedicated encoder.
Popular encoders include TMPGEnc and Cinema Craft Encoder. There are lots of guides and articles on this site about using both of these.
Your audio sync problem is probably less likely to arise if you use a proper encoder - and if you still experience it, there are many many tips about how to fix it on this site. Try reading some guides, and searching in the forum (a lot of people call A/V sync problems lip sync problems, if you're searching).
cheers,
mcdruid. -
i was using nero vision express 2 with no lip sync problems but had to format my hard drive due to an xp problem now put nero back on and i have lip sync problems so there is a codec out there because i had the right setup and lost it .
now im trying to sus it out..??
Nero Vision Express 2- DVD-video/merge titles causes stuttering
By mookster in forum Authoring (DVD)Replies: 0Last Post: 18th Jun 2008, 10:44 -
Encode mpeg-1 layer 3 in AVI to AC3 surround in Nero Vision Express 3
By jimbojr in forum AudioReplies: 0Last Post: 18th Feb 2008, 19:51 -
Sudden problem with Nero Vision Express 3.1.0.0
By smackyourfupa in forum Authoring (DVD)Replies: 8Last Post: 3rd Nov 2007, 16:56 -
AVI won't run in Nero Vision Express 3
By loninappleton in forum Video ConversionReplies: 3Last Post: 9th Oct 2007, 13:33 -
better tha nero vision express
By cesarin in forum Authoring (DVD)Replies: 1Last Post: 24th Jun 2007, 13:34
