Okay for some reason no matter what software I use when I burn a CD it cannot be read. I am using Memorex 700Mb CD-RW 4x, i have always used these CDs. I have tried using Nero, the tool I usually use, Alcohol 120% and Windows itself. Even burning a single file does not seem to work. But yet all the programs say that the burn was completed and the CD has been burned to as I can see it. ISOBuster cannot read it either. When i just burned a few file to the CD and tried read it with ISOBuster I got this error "The Primary Volume Dectiptor (PVD) is unreadable. Read Error at address 16." Anyone know why this has started to happen.
Thanks for any help.
Okay it now seems that its just CD-RW that have the problem. I have just burned a CD-R and it worked. This is just weird.
what kind of burner do you have? it didn't help much when you didn't specify your burner.
Always share what you have learned from others... -
Cdrw do not last forever, sometimes they don't last much. have you changed your writer or let someone else write to this cdrw?
The electronic components of the power part adopted a lot of Rubycons.
DVD ripping content is not completed on my Mac?
By seth fang in forum MacReplies: 4Last Post: 22nd Apr 2012, 22:51 -
Replacing/Adding Audio To Completed DVD?
By hech54 in forum Authoring (DVD)Replies: 3Last Post: 23rd Jan 2010, 08:58 -
optical drive can read but will not burn
By marx321_04 in forum DVD & Blu-ray WritersReplies: 10Last Post: 6th Nov 2009, 05:50 -
No sound plays on completed DVD
By Zippity in forum AudioReplies: 4Last Post: 27th Nov 2008, 15:39 -
YAMB creation completed without work done.. help please?
By LOGiC in forum Video ConversionReplies: 3Last Post: 16th Jan 2008, 23:38
