Are you using AUDIO_TS folder if you want to make an Audio DVD?
Or is it just the VIDEO_TS thats in use?
By audio DVD do you mean DVD-Audio disc ?
The DVD-Audio format uses the Audio_ts folder, and in it you will find .AOB files. (Although a lot of DVD -Audio discs are hyrbid DVD Audio/Video...this means you will also find stuff in the Video_ts folder too..normally a AC3 5.1 mix version of the album)
Authoring software is very expensive though, the cheapest i have seen is $500 for DiscWelder. (You can get a non-functioning demo from their website).
I have a Panny DVDS75 that play DVD audio discs, but so far Ive only got Metallica's Black album.
How do I burn Video_TS & Audio_TS files using DVDFAB?
By slayerbizkit in forum DVD RippingReplies: 8Last Post: 22nd May 2011, 19:18 -
Making dvd with audio files only
By ian c-nall in forum Newbie / General discussionsReplies: 7Last Post: 14th Dec 2009, 06:19 -
Making an audio dvd with wav & mp3 files
By wwervd316 in forum AudioReplies: 1Last Post: 18th Mar 2008, 21:41 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03 -
No Audio_TS files?? HELP!!
By onlyoneman in forum Authoring (DVD)Replies: 5Last Post: 8th Jan 2008, 11:19
