Hi all,
I have a mpeg1 file coded with tmpgenc (352x288 pal) with (1:1 vga) aspect ratio, so when full screen is activated there are two vertical black box at left and right of the screen.
Can I change the aspect ratio to (4:3 pal) without recompress the file with tmpgenc?
Now, I have not the original video stream!
Thanks in advantage
Results 1 to 12 of 12
You can use Pulldown.exe to change the aspect ratio flag on an mpeg, but most players will ignore it since MPEG-1 supported only 4:3. To make matters worse, pulldown doesn't work on MPEG-1 files, although others might. Typically, any physical change to an mpeg will require re-encoding.
Impossible to see the future is. The Dark Side clouds everything... -
Thanks for your reply!
I have an mpeg 1 so i can't use pulldown.
(anyway wery interesting utility)
Hey people, I'm waiting for other suggest!!
Help me please -
I do seem to recall a GUI version of PULLDOWN (not the batchfe pulldown gui, but a separeate product which did not use a dos EXE underneath), which may or may not work. I've never tried that one with MPEG-1 either. Check the tools section. It was buggy when I first tried it, and I quickly lost interest (the Pulldown.EXE GUI works fine for me
), but it may have what you need. Again, this is only a possiblity. I don't know if it will actually help in your situation, but I supposed it's better than nothing.
I think it was 'DoPulldown' or somesuch. Let me dig around.
Yep. Found it here: http://www.doom9.org/index.html?/Old_news/march03.htm
Just search the page for DoPulldownImpossible to see the future is. The Dark Side clouds everything... -
If the published source for pulldown matches the executable,
it should be able to change the aspect ratio on an Mpeg1.
MPeg1 is detected and the program continues if found.
That field is in the Sequence Header which an Mpeg1 has
I would hope that is not the source for the distributed version however,
it is a mess. Soon there will be a new one.
Change Aspect Ratio
By wulf109 in forum DVD RippingReplies: 1Last Post: 7th Feb 2011, 18:12 -
Best way to change aspect ratio....
By Han Solo1 in forum Video ConversionReplies: 13Last Post: 14th Oct 2010, 10:33 -
Aspect Ratio Change
By VicSedition in forum Video ConversionReplies: 9Last Post: 17th Feb 2010, 11:01 -
Have to change the aspect ratio - what is the right way??
By Weef in forum RestorationReplies: 25Last Post: 4th Mar 2009, 13:14 -
change aspect ratio
By zinc in forum Video ConversionReplies: 2Last Post: 23rd Jun 2007, 09:21
