can anyone tell a good tool to use for compressing a large svcd e.g 1.3g to a small avi file?
ive tried v.dub mod but it dont compress it much.
am i doing something wrong?
THANK'S
How small of a file size do you want? I do SVCD mpeg2 files to divx via virtualdub without problems. Typically if the mpeg2 file = 1.5GB or so I can get the divx file to about 650 - 700MB using a 2 pass encode.
In the divx 5.1 codec settings I disable profiles.
set bit rate to 650 kbps
scene change = 30%
psychovisual = fast
encode as progressive, keyframes = 300
For the first pass I set performance/quality to Fastest, for the 2nd pass I set it to Standard.
My audio compression settings are Lame mp3 @ 128kbps CBR stereo.
For the first pass I don't run any audio - set virtual dub Audio options to No Audio for the first pass.
VirtualDub video filters:
resize - set to 640x480 to get the correct aspect ratio.
null - crop out the black bars if your movie is letterboxed.
I run the filters on both passes.
I've only done 3 SVCD formatted movies with the 5.1 codec and so far so good with those settings but I'm sure they can be tweaked a bit so that it runs slightly faster on my system.
I've an AMD 1800+ running at 1533Mhz and a pair of WD 80GB 7200rpm HDs and it can take up to 8 or 9 hours to do a full 2 pass encode here. Running on WinXP home and I set the virtualdub.exe process to a lower than normal priority so I can do other things while the encoding is going. -
You should try Dr DivX. It's probably the easiest way of getting video into DivX I've found yet.
Vdub script / tool etc - split large file into 10 min segments? (auto)
By Jynks in forum Newbie / General discussionsReplies: 0Last Post: 17th Apr 2010, 06:19 -
adding subtitles to AVI (xvid or divx) WITHOUT re-compressing
By truthlesshero in forum SubtitleReplies: 2Last Post: 22nd Dec 2009, 10:43 -
Philips DVP5992 plays AVIs, Divx too large
By strommsarnac in forum DVD & Blu-ray PlayersReplies: 3Last Post: 10th Dec 2008, 22:32 -
large file split for multiple displays and convert ... what tool 2 use?
By rodpacker1 in forum Video ConversionReplies: 3Last Post: 13th Oct 2007, 03:03 -
Dr. DivX converts large VOB files into tiny unusable divX files
By texas1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2007, 21:44
