I know how to use DVD2SVCD but I can't figure out how to increase the number of mpg or bin files so that I can get the file size below 700 mb per disk.
They are a little to large for me to burn and when I go to the overburn mode my Nero program still says the blank cds are too small.
They are 80 min. cds.
Thanks Brad
If you let DVD2SCVD make cue/bin files, you can burn them in Nero 'image' mode. You should be able to burn SCVD's to 800 meg easily on 80 minute disks. I don't use overburn. Alternately, you can go to the 'bitrate' page and decrease the size of the CD's. Image mode lets you put more information on the disk.
Thanks redwudz.
A part of my problem is I am dealing with a limited size harddrive.
But I will use your advice and play with it.
Brad
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 18:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 17:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 10:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 01:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 17:08
