sure, but it will be contained within a disk image.
just do like you normally do then instead of burning, just save to disk as disk image. then mount and use that video_ts folder for dvd2one. -
yea, but you could always run that dvd though dvdbackup 1st, then continue with the normal process....
thats ridiculous.
Toast shoulnt make encrypted discs... I dont think it does at all. -
right, I thought he/she was asking about putting a file into toast, say a .avi and it says you need 5 gigs to make the dvd.
so instead of giving up he/she wanted to just save the video_ts folder to the HD, then dvd2one it so it would fit on a dvdr.
i dont see any problem doing this.
VIDEO_TS 7GB to VIDEO_TS 4GB
By klemyz in forum ffmpegX general discussionReplies: 2Last Post: 9th Dec 2009, 13:43 -
Video_TS folder has no menu(s) in Toast 10
By JonnyPhoenyx in forum MacReplies: 1Last Post: 8th Mar 2009, 16:02 -
Toast 9 Video_TS burning + aspect ratio
By brumos in forum MacReplies: 1Last Post: 29th Jul 2008, 08:34 -
Did toast 9 do away with audio export?
By stanislawski in forum MacReplies: 2Last Post: 1st May 2008, 03:36 -
Can't Toast VIDEO_TS ( not copy protected)
By rotuts in forum MacReplies: 3Last Post: 21st Jun 2007, 15:28
... So what we're saying is, yes you can use Toast, but only if your DVD isn't encrypted with CSS. If it is, use DVDBackup instead.
