Hello All,
I am new to this site, what DV format does a camcorder record its information in?
I looked at the Canon site for my camera but it wasn't specific as what type it records.
My information is in the signature.
Trying to match up software to accept the output.
Phil
Results 1 to 17 of 17
Canon Optura 20 for Video
Dell for Processing
TDK for Burning
Software? Looking for the Holy Grail -
DV format. However you can store it on your computer in Type 1 or Type 2. Type 2 is the most commonly used. Depends what program you are going to use it with. Check the glossary here for more informationhttps://www.videohelp.com/glossary#DV
DV1 interleaves the video and audio streams.Pros:very good audio synch,Cons:less compatible with encoders.
DV2 separates the video and audio streams.Pros:very high compatibility,Cons:audio may not synch.
http://thetechnozone.com/videobuyersguide/Codecs/Type1-Type2-DV.html
TMPGEnc accepts type 1 or 2. -
I guess the next question would be:
The camera doesn't determine format, the software does?
Also I am having a problem with TMPGEnc, and was trying to find fault with the DV format. Looks like I need to look somewhere else for that one.
PhilCanon Optura 20 for Video
Dell for Processing
TDK for Burning
Originally Posted by Tommyknocker
Opening it back up and looking at the log it says file conversion failed but the file is converted and usable.
I want to convert mulitple clips and can setup a batch but it only does the first one and shuts down.
I don't get any error messages during the process.
Dell for Processing
TDK for Burning
What was the name of the source file, and what was the name of the output file?
Hello. -
I renamed the source file and moved it before I set it up.
Working right now so I can't be specific but I had some clips from St Augustine and named them fort1 fort2 fort3 .avi etc.
I don't remember if I setup the capture with a specific name or let whatever software I was trying at the time to do it.
After the conversion the file type changed to .mpg with the orginal prefix.
Do you think that might be the problem?
P.
Originally Posted by TommyknockerCanon Optura 20 for Video
Dell for Processing
TDK for Burning
I hope not. If you let the software name the file, you run the risk of naming the output file the same as the input file, which your program cannot do because the file name is in use, causing an error, and making your process shut down.
Hello. -
So what you are saying is to set the input file to xxx.avi and the output to yyy.mpg to prevent this?
Dell for Processing
TDK for Burning
OK, I will give it a shot tomorrow after I wake up and let you know the outcome
Dell for Processing
TDK for Burning
NO Joy today, no matter what I tried it still closes after processing. Maybe I have a bad install with this program.
Might just finish this project using it like it is and then wash it out and try again.
Phil
Dell for Processing
TDK for Burning
You need to convert the avi to Type 2, use the DV Canopus encoder tool, there are 2 in the tools section, but I found out that the second one (from DV1 to DV2) causes my avi file to lost it's sound.
I haven't tried the canopus, but I think it's better, but you have to go one by one; the other let you to select multiple files at a time.
It's weird because it use to work fine before. Now it closes every time it finishes or when you have batch encoding. -
I'm facing the same batch-encoding problem. I've yet to try converting to DV Type 2.
But then I've been using DV Type 1 all the while but only encounter this problem recently. And the weird thing is this. I had 2 computers with WinXP, and I'm using Tmpgenc 2.59 on both PCs. I tested the same set of avi files (type I) on both computers. Batch encoding work ok on 1 set but not in the other computer. -
It used to work fine for me until recently. Do you have all the updated installed? I'm thinking some XP updates caused the problem
Hello All,
Had a few minutes this morning and managed to try converting a AVI 1 to 2 using DV Canopus encoder. It worked fine and didn't take very long. Then I sucessfully converted it to MPEG 2 using Tmpgenc and it did not close at the end like it had been. Didn't have time to try a batch yet, but it looks like I am over one of the hurdles.
I think I will investigate using a DV capture program so I can transfer it for AVI 2 and go from there.
Phil
Dell for Processing
TDK for Burning
Convert DV type 2 to type 1? Or is there an app that will correct sync?
By Colmino in forum Newbie / General discussionsReplies: 7Last Post: 20th Dec 2022, 21:24 -
How to convert a trp type file to Mpeg2 type?
By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 15:59 -
Seeking "One-Type-Fits-All" format to display on iPod, PSP and Bl
By GrayStrickland in forum Portable VideoReplies: 0Last Post: 25th Mar 2008, 09:12 -
DV AVI Type 2 -> Type 1 converter?
By alx3d in forum EditingReplies: 3Last Post: 29th Dec 2007, 20:16 -
Convert Type 2 DV to Type 1 (DVdate?)
By nlec in forum Video ConversionReplies: 30Last Post: 30th May 2007, 13:52
