I am looking for a new method of "editing" previously authored DVDs.
Basically I want to be able to added new footage to a DVD+RW at a latter date and change the menu to have a new thumbnail.
My current method is:
1.) Transfer DV footage to PC via firewire
2.) Edit in Premiere 6.5 (usually end up with ~5min clip)
3.) Encode DVD compliant mpg using the Mainconcept encoder
4.) Author a simple menu in a DVD+VR complaint software package
So far, the authoring apps I have used are:
Ulead DVD Movie Factory 2 - currently my top choice - Just doesn't allow for much creativity.
Nerovision Express 2 - complete garbage - never once was able to author a DVD without a crash
DVDit LE - Have not used much, because I wanted the +VR format.
My question is... Is there a better way (what software do I need) to edit my DVD+RW disk (menu and more footage)? I would like to use try other authoring programs, but i don't know if I could add stuff later. (I don't want to keep all the mpg files on my hard drive.)
Hopefully this makes sense.
Thanks for your opinions,
PS: here is a list of my "nice to have" features in the DVD authoring application:
The ability to creat buttons that go to another menu (not a movie clip)
thumbnails that show the actual clip moving
Intro movie (before the menu)
transitions clips between menus
Results 1 to 1 of 1
How add a subtitle to a bluray disk and then convert from 50 GB to 25 GB
By siopilos in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Feb 2012, 09:49 -
How to Add Deleted Scenes & make it complete version?
By skorpinok in forum Video ConversionReplies: 2Last Post: 1st Jan 2012, 06:29 -
add DVD subtitles to a bluray disk
By berendho in forum SubtitleReplies: 1Last Post: 30th Aug 2008, 17:30 -
I'm wanting to cut some scenes and add some fade-ins to a DVD video.
By Ryan J in forum MacReplies: 4Last Post: 17th Apr 2008, 08:42 -
How to make DVD recorder disk playable on TV with all scenes intact?
By Stabes in forum Newbie / General discussionsReplies: 1Last Post: 29th Dec 2007, 14:02
