Results 1 to 26 of 26
  1. Ok I've been trying to get my burned dvd's to work now FOREVER, i can burn the dvd's but the weird thing is they ONLY play on my dvd burner drive...they wont play in my normal drive on my computer and they wont play in any of the dvd players i got in my house. When i burn the dvd do i burn video_ts?? like what do i burn in order for it to work. please help im desperate and getting sooo mad.
  2. Need more info. Explain the proces that you are using including the tools as well as what you are trying to play these discs on.
  3. Member FT Shark's Avatar
    Feb 2002
    Land Down Under
    You need to tell us exactly what you are doing, step by step, in order to get help?
    What kind of files are you burning? What is the folder structure of the dvd you are burning (video_ts and audio_ts)? Ect...
  4. Member GKar's Avatar
    Jul 2003
    In the corner, on a stool
    I hope you were practicing on DVD-RW's!
    May 2003
    Pal Realm
    Hmmm. Does not seem a single guide or even What Is DVD was read before SHOUTING!! a panicky plea. :c( SERIOUSLY!!!!
    There's no place like 127.0.0.1
    The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
    Dec 2002
    The Great Northwest
    DITTO
    CAN'T THEY READ, AGAIN AND AGAIN IT'S THE SAME QUESTIONS!!!!! sorry but come on people!!
    (;-{> Dd
    Strength and Honor
    www.dvd9to5.com
    www.dvd9to5.com/forum/
    "For every moment of truth there's confusion in life"
    Black Sabbath/Ronnie James Dio
    May 2003
    Pal Realm
    Not only that :c( but they cross-posted with their second post https://www.videohelp.com/forum/viewtopic.php?t=185111&highlight=
    Didn't like the one answer - it asked for more info, so they tried their luck again.
    Not a good start.
  8. ok this is what i do in order to burn my dvd
    1. I use dvd decrypter
    1. Select Mode -> ISO -> Read
    2. Select your DVD Drive.
    3. Under Number of layers it should say 2, it is a DVD-9 disc.
    4. Select Mode -> FILE
    then i decrypt it
    2 I then use DVD2ONE-the source is VIDEO_TS
    3.I burn it with COPYTODVD
    1. Select File -> Write DVD Video
    2. Select the video_ts.ifo file that you find where you converted your video.
    and thats all i do but it wont read on any of my dvd players i got a technosonic dvd player and a toshiba dvd a sanyo dvd player and a little portable mustek dvd player. It doesnt work on any of them. It will only play on my dvd burner drive.
  9. oh by the way sorry if i got you guys mad by posting that seems liek you guys seemed to get a bit mad you got to exscuse me im really new at all this, sorry once again.
    Jul 2002
    Scotland
    What format of media are you using, -r or +r.
    Some players and dvd rom drives are very picky about media.
    As said above use rw discs.
  11. Don't apologize there not ADMINs they just like to bitch. I used to copy and burn the exact same way you do and I never had any problems. Are they DVD-R's or DVD+R's what brand and what kinda DVD burner? Like what dlb said. Oh, -R's won't work in anything but your computer. Try using different software too, DVDshrink is easy (faster too) then use COPYtoDVD
  12. This sounds like another case of just burning the DVD files to DVDR. The files should be put into a VIDEO_TS folder then only that folder is burned, otherwise the burned DVDR will play on the computer drive but not on any DVD player.
  13. Originally Posted by 808smokey
    And where did you get THAT ridiculous Idea
  14. Originally Posted by bugster
    Exactly, I only use -r's and they work in everything
    If it's wet, drink it
    My DVD Collection
  15. Wow, I'm not sure what i was talking about. DVD-RAM maybe... Brain fart I guess LOL
  16. Originally Posted by 808smokey
    There are a number of standalone DVD recorders that use DVD-Ram, but other than that, well, I suppose thats what you could have been thinking of
  17. Look what I just found in this Website under WHAT IS DVDR
    DVD-RAM
    DVD-RAM has the best recording features but it is not compatible with most DVD-ROM drives and DVD-Video players. Think more of it as a removable hard disk. DVD-RAM is usually used in some DVD Recorders.
  18. 808smokey,
    Huh, ya, your point was? DVD -ram only plays in some devices, not real common, but I do have a set top recorder player I can use it on too, besides the PC.
    I think you said -R first time, -R plays on almost anything that plays DVD BUT not everything!
    As for first post, burn the folders VIDEO_TS and AUDIO_TS to your -r disks. You should have .vob .ifo .bup files in the VIDEO_TS folder and the AUDIO_TS folder is normally empty.
    Also notice both folders are all in CAPS!!!
    Maybe a typo but you mentioned a video_ts.ifo, no that is not correct! It should be in the folder, not a file by itself.
    It would be good to check out the guides. If it seems some people get grumpy, it's because newbies seldom read guides or do searches, but ask the same questions 3 or 4 times a day!
    Also read any manuals or guides that came with your software if you haven't already.
    Hey Gees, did you change you avatar? Where the angels??
    overloaded_ide
    Spambot FOOD
    Anti-Spam
    May 2003
    Pal Realm
    The angel wings are still there. :c) I wanted a change for Halloween. Hard to change just the wings so I stuck them on GIR, my favorite character from my favorite cartoon, Invader Zim. :c)
    Mar 2003
    Kansas City MO
    Gee, I do the same thing and Baldrick gives me a little "Yellow Pill". Thats why I stopped donating to this site on a monthly basis. The rules get applied to some and not others. Hmm?
    Jan 2003
    California, USA
    then i decrypt it
    Hmmm, your method seems a little too taxing for a beginner. Have you tried just using DVDShrink and Nero?
    Guides for DVDShrink can be found here:
    For version 2.3: http://www.dvdshrink.info/re-author.php
    For version 3Beta: http://www.dvdshrink.info/re-author-v3beta5.php
    And guides to burn the resulting DVDShrink files with Nero can be found here:
    http://www.dvdshrink.info/nero-video.php
    This was and still is the method I use and every newbie I've ever met have had no problems with this method.
    Give a try
  22. Member
    Sep 2003
    paintball field in CA
    I think DVD Shrink is the answer to all DVD burning issues and it even freshens your breath. Totally amazing. Did we figure out if the stand alone player accepts DVD-/+R media? Or was he poping in RW?
  23. Originally Posted by jdizzy40
    Yes, the world is against you obviously... I believe the reason you were warned was clear: https://www.videohelp.com/forum/search.php?search_author=jdizzy40&search_warning=1
    Regards.
    Michael Tam
    w: Morsels of Evidence
  24. Member
    Mar 2003
    Kansas City MO
    Oh yes, that was so terrible. How about another one. Kiss my ******* ass! Jew bastard!
    You are in breach of the forum rules and are being issued with a formal warning. Please grow up.
    / Moderator vitualis
  25. Hey, you're the one who brought it up... Not to mention that the only people who can see your "yellow pill" is yourself and the moderators. The purpose of the marker is a reminder for you and a way to keep tabs for us.
    If you don't like the system, complain in the "feedback" section of the forums. Following the rules ( here ) helps. Also, membership is voluntary.
    Regards.
    Michael Tam
  26. ok i follwed the steps that febre told me to do....everything i did...i even did it in iso mode too and both times they didnt play!!!!!!!!!!!!!!!!!!!!! why i have dvd+R that i tried it on and it wont let me try with with my dvd-RW...but still the DVD-R didnt work on any of my dvd players and i got 4 different ones. Im so mad and confused.lol
