I need to create a image/iso or bin file of my vob files, is there a good software that i can use ?
Nero6 complains about to big file ?? (4,56GB) when burning a DVDR. Maybe I can burn it as an image ??
maybe it is to big ..
you can burn img files with DVDDecrypter"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
IMGtools available at www.doom9.net is a great program for creating img files.
If you are going to burn an ISO or IMG file I suggest using Decrypter.
The only thing about IMGtools is you will have to have the VIDEO_TS folder in the root directory of a drive. So for example - C:\VIDEO_TS
but that's it, IMGtools will do what you want. -
Try using pdi2iso I use that as for some reason when I try burning from instant copy it says that the disk isnt big enough which it is (princo 4.3gig available) so I convert the pdi file to iso then burn it with dvd decrypter, wonderful job
Anyone know of a good MP3 program to resize (make smaller) some files
By soulbug in forum Newbie / General discussionsReplies: 4Last Post: 28th Feb 2011, 16:03 -
Good program from cut/join .mpg .wmv files.
By Beautiful Alone in forum EditingReplies: 1Last Post: 27th Jul 2009, 17:57 -
Good program to repair broken dvd files?
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2008, 19:22 -
how to correctly burn iso that FAVC makes using ImgBurn
By brentonboy in forum Newbie / General discussionsReplies: 8Last Post: 19th Dec 2007, 16:54 -
Whats a good program to recover deleted files ?
By StoneColdWhat in forum ComputerReplies: 15Last Post: 23rd May 2007, 22:12
