I have a panasonic dvd-cp72, if i copy a dvd ( PAL to NTSC) and remove the region restrictions, will the dvd play the way it should, or will i have dropped frames due to the 25 - 29.97 frame difference? has anyone tried this?
There are loads of threads about this. One very recent lengthy one. Try a search to find them. (87 matches - use advanced search topic tile/subject only)
A few Guides are here: https://www.videohelp.com/guides?tools=&madeby=&formatconversionselect=&osselect=&howtos...or+List+Guides
Just keep in mind, if you haven't already, :c) that region coding is totally unrelated to PAL vs. NTSC
The disc can not be converted while copying. It needs to be re-authored. Perhaps you know that. :c) You do mention the different framerates, but don't mention how you plan to go about it.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
thanks for the reply, i did the re-author, and the audio is out of sync, so i was just wondering if i remove the region restriction would it play properly, or drop frames.
Removing regions, as I said, has nothing to do with it. When you author a disc it is region-free anyway. :c)
You'll need to head to those guides and links, I'm afraid, to sort any sync issues.There's no place like 127.0.0.1
Pal 25i to Ntsc question
By spiritgumm in forum Video ConversionReplies: 17Last Post: 15th Dec 2011, 18:16 -
PAL to NTSC question
By rayden54 in forum Newbie / General discussionsReplies: 11Last Post: 2nd Apr 2011, 21:59 -
PAL vs NTSC Question
By cottage in forum Video ConversionReplies: 26Last Post: 6th Jul 2009, 09:53 -
Total Noob Question - NTSC / PAL
By fredfillis in forum DVB / IPTVReplies: 15Last Post: 10th Jan 2008, 05:16 -
pal/ntsc lcd monitor question
By scotstrength in forum Media Center PC / MediaCentersReplies: 0Last Post: 30th Oct 2007, 12:17
