Hi,
I try to encode a 115 min movie using these parameters (extract from ffmpegX log):
printf "Encoding started on " && date && /usr/bin/mencoder /Volumes/Mystic/TV/MissionImpossible2clean.dv -oac mp3lame -lameopts cbr:br=128:vol=0 -aid 1 -ovc lavc -sws 1 -lavcopts vcodec=mpeg4:vbitrate=1154:keyint=240:vhq:vqmin=2: vqmax=9:cmp=1recmp=1
ubcmp=1 -ofps 25 -vop scale=576:357,crop=700:434:10:70,lavcdeint,denoise 3d -o /Volumes/Mystic/TV/movie.avi && printf "Encoding completed on " && date && printf "\a"
All seems OK (see complete log) at the end, but the resulting movie file is only 10 min long
Could you explain me I'm a new user.
File not found: 'frameno.avi'
Mon Oct 27 10:38:33 CET 2003
Using GNU internationalization
Original domain: messages
Original dirname: /sw/share/locale
Current domain: mplayer
Current dirname: /usr/local/share/locale
MEncoder dev-CVS-030226-15:00-3.1 (C) 2000-2003 Arpad Gereoffy (see DOCS)
AltiVec not found
Reading /Users/pascal/.mplayer/codecs.conf: Reading /usr/local/etc/mplayer/codecs.conf: 55 audio & 141 video codecs
Reading config file /Users/pascal/.mplayer/mencodersuccess: format: 0 data: 0x0 - 0xB51CEC00
RAWDV file format detected.
[V] filefmt:22 fourcc:0x44535644 size:720x576 fps:25.00 ftime:=0.0400
Opening audio decoder: [libdv] Raw DV Audio Decoder
AUDIO: 48000 Hz, 2 ch, 16 bit (0x20), ratio: 3600000->192000 (28800.0 kbit)
Selected audio codec: [libdv] afm:libdv (raw DV audio decoder (libdv))
Requested video codec family [qdv] (vfm=dshow) not available (enable it at compilation)
Opening video filter: [expand=-1:-1:-1:-1:1]
Expand: -1 x -1, -1 ; -1 (-1=autodetect) osd: 1
Opening video filter: [scale=576:357]
Opening video filter: [crop=700:434:10:70]
Crop: 700 x 434, 10 ; 70
Opening video filter: [lavcdeint]
Opening video filter: [denoise3d]
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffdv] vfm:ffmpeg (FFmpeg DV decoder)
MP3 audio selected
Building audio filter chain for 48000Hz/2ch/16bit -> 48000Hz/2ch/16bit...
Writing AVI header...
VDec: vo config request - 720 x 576 (preferred csp: Planar YV12)
VDec: using Planar YV12 as output csp (no 1)
Movie-Aspect is undefined - no prescaling applied.
SwScaler: reducing / aligning filtersize 4 -> 3
SwScaler: BILINEAR scaler, from Planar YV12 to Planar YV12 using C
New_Face failed. Maybe the font path is wrong.
Please supply the text font file (~/.mplayer/subfont.ttf).
subtitle font: load_sub_face failed.
videocodec: libavcodec (576x357 fourcc=58564944 [XVID])
High quality encoding selected (non real time)!
Skipping frame!
Skipping frame!
CBR audio: 16000 bytes/sec, 384 bytes/block
Writing AVI index...
Fixing AVI header...
Video stream: 1157.029 kbit/s (144628 bps) size: 86268077 bytes 596.480 secs 14914 frames
Audio stream: 128.000 kbit/s (16000 bps) size: 9552000 bytes 597.000 secs
Encoding completed on Mon Oct 27 12:15:58 CET 2003
Results 1 to 1 of 1
AnonymousGuest
Bitrate Limit for BD9?
By wulf109 in forum Blu-ray RippingReplies: 4Last Post: 6th Jan 2012, 07:56 -
How do I get around the 5x change limit for DVD's
By trekker2u in forum Newbie / General discussionsReplies: 5Last Post: 1st Feb 2011, 00:25 -
Is there a Min/Max limit for I, B & P frames for NTSC DVD ?
By Movie-Maker in forum Newbie / General discussionsReplies: 13Last Post: 6th Nov 2008, 13:51 -
Limit playback to first 20 seconds?
By jeff.mikolai in forum Video Streaming DownloadingReplies: 4Last Post: 20th Mar 2008, 15:47 -
What's the time limit on a DVD?
By PlayWithFire in forum Newbie / General discussionsReplies: 7Last Post: 22nd Nov 2007, 12:20
recmp=1
