Hello-
I have SONY DVD Writer 510A. Can someone please tell me how to recored over 2 hours of video on to it.
Or what is the max I can record?
Thank you
Results 1 to 9 of 9
I regularly get 4+ hours of loony toons on a disk.....
DVD supports a MAXIMUM of 10Mb per second (Mega BITs)
@ 10 Mb/sec = 1Hr (8Mb video - .3Mb Audio + overhead)
You can use A Lot Fewer bits and extend the time recorded.
Most comercial DVDs are around 4-6Mb/sec
What are you recording and compressing with?
Using software on the PC is the best way to get nice quality and long playing times.
gNOME... -
The max is based on what bitrate you use.
You can get quite acceptable quality in 1/2 D1 resolution and get around 4 hours/DVDR . It all depends on the source and your Audio.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Yeah,
I forgot to mention, to get 4+ hors on a DVD I encode the video at SIF resolution
Thats 325X240
And I use Variable bit rate Min. 200K Ave. 1150k Max 1600k
DVD supports several resolutions:
720x480
704x480
352x480
352x240
As you try to squeeze more time on a disk - you lower the bit rate.
As you lower the bitrate - artifacts appear.
To prevent artifacts - you lower the resolution.
Lowering the resolution makes for a Less Sharp picture, but lower bit rates work efficently. -
I am using Pinnacle Studio Delux to put it on DVD-R.
Lowest it lets me do is 3000. with around 2 hours video.
Was wondering if any other alt. ways?
Thanks again. -
Originally Posted by gNOMEintheRedHatEjoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
I basically agree with money69 but I'd encode half D1 (352*480 NTSC) - then you won't have to make sure the standalone DVD is SVCD compatable.
I often burn 3 movies to a DVD+R (upwards of 6 hours) and quality is very good. When backing up DVD's use film framerate - seems to make better quality for the same bitrate. -
You might want to try DVD Shrink to reduce the size of your current files. It is available as freeware.
https://www.videohelp.com/tools?tool=155#comments
Another program for 6 hours on 1 DVD
By Torben in forum Authoring (DVD)Replies: 7Last Post: 14th May 2010, 11:10 -
Hours of Music without Hours of Video Data in DVD Architect
By Guff22 in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2008, 21:23 -
fitting four hours on 4.7 GB DVD
By cthiesen in forum Newbie / General discussionsReplies: 34Last Post: 13th Apr 2008, 16:36 -
20 Hours on a single DVD?
By Alienverse in forum Authoring (DVD)Replies: 45Last Post: 26th Oct 2007, 13:11 -
What Is The Best Way To Fit 2 Hours On A DVD?
By Anakin in forum Video ConversionReplies: 14Last Post: 4th Jun 2007, 11:52
