I would like to select the original video resolution and not have to scale at all but I'm forced to enter values in the fields which I'm not sure about... video info shows 720x576 (letter box 2.35:1) so I'm cropping the video but I dont want to end up upscaling either because ffmpegX auto detects 718 436 2 70 (718 -> upscaling 2pixels ?). Finaly what scaling method should be used, if the video is not actually scaled, does that matter ?
MKV & Adobe premiere: Best method to import without quality loss
By libjoe67 in forum EditingReplies: 34Last Post: 19th May 2012, 16:34 -
what resolution will a DVD recorder set-top capture.
By xbill in forum DVD & Blu-ray RecordersReplies: 6Last Post: 11th Jan 2012, 16:40 -
Trying to keep original resolution, but programs seem to auto crop/resize
By nyder in forum DVD RippingReplies: 3Last Post: 14th Aug 2011, 04:34 -
Convert DVD to Xvid using original resolution
By iBeech in forum Video ConversionReplies: 5Last Post: 13th Jan 2009, 11:05 -
How do you set video resolution in HCenc?
By Maikeru-sama in forum Video ConversionReplies: 3Last Post: 5th Sep 2008, 15:15
