Hi All,
First-time poster so go easy![]()
I'm having trouble with what file size i should be aiming for when re-encoding an MPEG in TMPGEnc Plus.
It gives me lots of variables with regards to bitrate bit I looked in the preferences of DVD Shrink and one of the options was to fit/shrink the file onto a 'DVD-r 1.0 (3.95)Gb (roughtly 3,7000Mb).
Is this the file size I should be aiming for as I've had a few DVD's burnt over this figure and they jump at the end. Also my standalone player (Philips 710) needs to have the file size *over* 4Gb - it says over but a 3.94Gb DVD plays fine...
What file sizes does everyone set in TMPGEnc so you have 100% sucess rate???
Any help would be greatly appreciated.
Asus A7N8X-Deluxe
Athlon 2600+
120Gb Western Digital Caviar
120Gb Lacie D2 External
Windows XP SP1
Pioneer 106D
Using Bulkpaq Orange Top DVD-R's
3.95 is for Authoring DVD's, 4.3 GB is for DVDR's .
Never heard of a plyer requiring more than 4 GB for a DVD, smells like BS, no offense.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Well, I've just tried a 3.69 Gb DVD-R and it didn't play. Also read a couple of reviews of the machine and they also said it had a problem with DVD's lower than 4Gb in size.
I will try the 3.95Gb encode first in TMPGEnc.
Is there any special trick you can use to ensure the DVD plays all the way to the end without it starting to skip?
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 17:23 -
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 20:09 -
Long-Term Storage - Verbatim DVD-R 16x (MCC) still BEST/IDEAL ?
By quantass in forum MediaReplies: 7Last Post: 29th Jan 2010, 01:14 -
DVD to AVI ideal settings
By jbaruch76 in forum DVD RippingReplies: 11Last Post: 4th Nov 2008, 17:40 -
Ideal DVD Recorder for this job...
By retroborg in forum DVD & Blu-ray WritersReplies: 9Last Post: 17th Sep 2007, 16:29
