Hello , yes Iam a newbe. I just hooked up a ATI 9000 pro capture card to my pc and everything works ok. One particular movie I own will not capture( sound ok video looping). I thought the problem was Macrovision
so I played it throgh an old vcr that i know is macro free. I copied the tape to the old vcr and it still will not capture. I am not asking how to hack MACROVISION , I just want to know 2 things
1) is it a macrovision problem
2) even though I play the tape on a unit that is MACROVISION free
the capture card will still see that it is encoded with macro and enable it
tenderland
Most likely it's macrovision. This device will remove it but it's not cheap.
http://www.facetvideo.com/ -
You assume that Macrovision is part of the VHS player and not embedded in the tape.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
www.lordsmurf.com might help ya. Look under "Capturing AVI with ATI Cards" in the Microvision paragraph.
Good luck.
Macrovision Question
By matthewjohn23 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 7th Jun 2011, 15:19 -
Macrovision like NONE OTHER
By blacksheepdownunder in forum Capturing and VCRReplies: 17Last Post: 22nd Jul 2010, 04:16 -
Is it Old or is it Macrovision?
By Tiggerpaws in forum RestorationReplies: 4Last Post: 7th Aug 2009, 16:31 -
Macrovision
By adamrose in forum Newbie / General discussionsReplies: 15Last Post: 22nd May 2008, 20:41 -
Macrovision Help!
By dollydoodledumplin in forum DVD & Blu-ray RecordersReplies: 11Last Post: 24th Nov 2007, 10:37
