Results 1 to 9 of 9
  1. I have a amd t-bird 900Mhz, raid-motherbord with 1 IBM 20gb dma66 7200rpm hd, 256mb sdram and Gainward GF2 mx400 VIVO. Frames are dropping like hell in Virtualdub, I wonder why? Tried different resolutions, compresson quality and almost everyting I could think of.
    Harddrive reads 17mb/s writes 17mb/s. Anyway I am gonna buy a new drive soon, need more space.
    Is it still too slow or what? Please help!!!
  2. You should not have any problems with that setup.
    I only have:
    Celeron 600Mhz
    320mb ram
    20Gb 5400rpm HD
    Pctv rave capture card.
    I can capture at 768x576 - 25fps - Pic video codec (quality 19) with no dropped frames when I capture with Avi_io.
    OH
  3. I have:
    p2-550
    128meg
    aiw-128/32 set to 480x480, 2.9kbiterate, me=22
    4gb os hd
    20meg x2 hd and 34meg hd in pull-out caddies for captures.
    it captures pretty well.
  4. Thats what I tought. This is so odd. Thanks for replying.
  5. Have you checked the DMA box for the drive itself. I was getting 4mb/s out of a drive that should do around 15mb/s - the DMA was not checked. When I checked the box - whoooosh!
    Cheers
    Adam
  6. Well, the I have a RAID controller on the motherboard and becorse of that the drive it self dosenīt have that dma checkbox like you have. The dma setting of the drive is managed by the contoller and its set to be dma. So it should on. I tested the drive several times and the result was between 10-16mb/s for D partition were I capture. C partition had low numbers 4-10mb/s.
  7. spl,
    Have you solved the problem with that Cardexpert setup? I'm looking to build a system and like the reviews about the cards display qualities. Moderately overclocked its numbers are close to GeForce2 Pro/GTS cards. I haven't found any info on its capture quality. Other than the frame drops you're talking about how is the quality of the pics? Also, have you tried the hardware MPEG1/2 coding?
  8. Havenīt solved the problem yet. Working on the mpeg2 capturing right now and have to say that it has its own problems. Mpeg2 cap quality isnīt as good as avi and the mpeg2 cap software that comes with the card has some sync problems with audio and video. Sound drops out in long mpeg recording that iīve done so far and invalid mpeg files. I think that a standalone capturing card with hardware compresson would be the best way to capture. You also need a powerfull PC to capture any mpegīs. At this point I donīt recommend this card.
  9. Thanks spl, I'll take your (and a couple other people's) word for it on this one.
