Every time I try to move the slide to FF the video, it frezees my computer. I had the same problem with DVD Movie Factory. I can't believe this is an ongoing problem, do they have a QA deparment?
Is anybody else experiencing this problem? I had to go back to my old and reliable videowave.
Yes, they have a tech support department. When the program freezes, is there any disk activity? When my VS 7 seems to stop working and I still have disk activity, I wait for it to stop, then it unfreezes.
Hello. -
Yep, you can move the mouse cursor, but you can't do anything. I waited for like 2 min and shut down the computer.
How long do you wait? I have a 2.4 Ghz so I don't think this program is taking a short time to finish.
I have videowave and it doesn't have this problem. It's not the best program but it fits my needs. -
I sometimes do have to wait a little. But VS 7 fits my needs and then some.
Hello. -
1. Click FILE > PROJECT PROPERTIES;Originally Posted by jgandara
2. Observe how your project properties are adjusted;
3. Do they match the properties of your source media?
4. What are the precise video/audio properties of your source media?
I have never encountered the "freezing" issue you describe.
But I am also careful to adjust my project settings in Ulead VideoStudio so that they match the precise video/audio properties of my source clips.
I have written a tutorial explaining how to capture video from a typical digital camcorder.
The tutorial begins on the page at the following link:
http://www.jonesgroup.net/videostudiodvcaptureone.htm
If you read the tutorial, you will note my DV .avi video/audio properties are as follows:
NTSC drop frame (29.97 fps)
Microsoft AVI files
24 Bits, 720 x 480, 29.97 fps
Field Order A
DV Video Encoder -- type 1
DV Audio -- NTSC, 48.000 kHz, 16 Bit, Stereo
I then adjust the project properties to *match.*
Then - FAST FORWARD and other controls work very, very well.
Jerry Jones
MPEG-4 Visual
By nirbhayn in forum Video ConversionReplies: 9Last Post: 4th Jul 2010, 14:43 -
Video Studio 9 SE problem
By eclipse95 in forum EditingReplies: 0Last Post: 9th Aug 2008, 17:41 -
Studio 11 Ultimate problem
By ingeborgdot in forum EditingReplies: 12Last Post: 14th Jan 2008, 14:53 -
Problem With MPG files in Studio 9
By BillP2 in forum Authoring (DVD)Replies: 3Last Post: 3rd Dec 2007, 06:49 -
visual studio 2005 pro problem with vista
By alsyed in forum ComputerReplies: 3Last Post: 18th Jun 2007, 12:29
