I have all these VCDs that i made and when i put them in the DVD player it says VCD then spits it out. Any ideas why it's doing that?
my mate had one of those phillips 701 , it seems to be very fussy as to wot bit rate it will play
it seemed to be anything higher than 1150 and it would not play, so all his vcd s are done standard bitrate basically he had to get rid of it coz it also played (vcd s ripped from region 1) in balck and white, hope this has been of some help
It may be the media problem. Try to burn with other brand. CD-RW is better than CD-R. I found that Mr. Write 4X CD-RW works on most DVD player.
Hey Cloner,
What DVD player should i buy then. ANything under $ 160 is good 4 me.
Restore a DVD+R that wont play
By ProfHiggins in forum MediaReplies: 10Last Post: 14th Dec 2009, 23:49 -
JVC Wont Play New DVD's!
By Raxxor in forum Newbie / General discussionsReplies: 2Last Post: 29th Dec 2008, 14:02 -
LG DVB-T wont play DVD's
By scdom in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Oct 2008, 08:20 -
My pana s97 and pana ex75 wont play my vcd's correctly
By ozizu in forum Newbie / General discussionsReplies: 0Last Post: 10th Jul 2008, 23:32 -
Will a Phillips DVDR3475/37 play DVD +R DL discs?
By c5vetman in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Nov 2007, 12:47
