I still have not found the answer to this. If we don't care about player compatibility (since -R/-RW and +R/+RW all seem to play in my player) what is the advantage of using -R/+R over -RW/+RW other than the cost of the discs to start out with?
Do write once R media last longer than RW? If I use an RW disc to backup a movie should I expect no problems at all in say 1 year if I want to burn a different movie on it. Is there any degradation in quality just from sitting with the same contents for a period of time on an RW as opposed to opening a brand new RW and putting something on it for the first time?
I am just starting out with recordable DVD's so I want to know what approach I should take. If there are no cons to RW media other than compatibility and price I may just end up using RW media all the time since I don't think I will be going though 100's of discs.
Thanks for any input,
-Darryl
With the exception of cost as you pointed out, speed of the burn is also a factor. As far as "down the road degradation", well only time will tell. Ask that question in 5 years or so and you can get a better answer. Family movies n stuff goes on a +R disc, movies I know I'll keep for a long time also go on a +R disc. Tv eps, data back up go on a +RW disc. It's really a matter of YOUR choice.
The phase change discs (RW) are not made to last forever.
Cheap media can last less than a year. Some 1x princo's from last year are already dead....maybe the marker ....maybe the label.
Generally speaking don't put you wedding video on a cheap disk. This is irregardless if it's R or RW. As to the +/- issue, it shouldn't really matter. The technical differences come up in other ways (speed and how the data is physically written).To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Thanks for the comments. I don't plan on buying any cheap media. It is just not worth it. So far mine are all TAIYOYUDEN, RICOH/RITEK, or MCC.
I know that nobody can know for sure yet about longevity but I was just trying to figure out if there was a big drawback to using RW's.
-Darryl -
Some of my +RWs are almost a year old and still going strong after lots of overwriting.
I really like them because formatting is not required before the first use.You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Most of the GOOD media have been testd in accelerated testing to last more than 80 years for -r(most likely +r), don't know about R/W disks, -Ram at more than 100 years. Accelerated aging tests may not show real life expectantcy (sp?) as can be shown by the disks that only last 1 year or less, and have been tested. Just buy good quality disks, like Ritek and Taiyo Yuden and the other good disks as listed in the comparison to the left.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Pros/Cons of M2TS with PS3
By figdog in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 19:37 -
Need help understanding pros and cons of different codecs
By shira in forum Video ConversionReplies: 4Last Post: 5th May 2010, 04:41 -
HDV vs. SD - Pros and Cons
By pooty13901 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 22Last Post: 19th Jan 2009, 07:54 -
LCD TV as Monitor- Pros and Cons?
By enter8 in forum ComputerReplies: 15Last Post: 22nd Nov 2008, 19:55 -
media pros cons...
By dvnoob in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 18th Aug 2008, 23:07
