Anyone in here have any experience with the LG-4040b drive? I need to be able to burn dvd-ram disks on my panasonic e80 and re-author them on my pc, then burn them to either a dvd-r or dvd+r disk, whichever will work best in old or new standalone players.
The disks I've burned play fine in my new standalone player as well as in my panny recorder. But, some of my disks won't play in older dvd players. I'm thinking about getting a pc dvd burner so I can create my disk on the Panny on a dvd-ram, put 'em in the pc burner, re-author them and then HOPEFULLY they'll play in whatever player I put it in, new or old, pc or standalone. Am I crazy in expecting this to be possible? I know some older players work better playing dvd-r and others better with dvd+r, so I need a dual format drive. Are their any drives besides the LG 4040b that's dual format that can also read dvd-ram, can burn consistently playable disks and can do so at 4x?
I want to be able to use my dvd-ram b/c otherwise, going from stand alone recorder to pc to dvd would require 2 disks for each burn rather than the dvd-ram and a dvd-/+r.
Any opinions are greatly appreciated.
Thanks!
In which thread? this one?
Or this one: https://www.videohelp.com/forum/viewtopic.php?p=693992#693992 ?
:c*
That's cross posting - against forum rules. You could have just edited your original thread.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Ooops, I combined them both together now into this post. However, the way the forum is set up, I can't deelte the orginal so I just removed the text from it and linked to here. That's the best I can do. Sorry.
Now, can you answer my question??? -
Maybe :c* You can not read your Panny discs with your DVDrom drive? I think that's what most users do. And many recommend not to use a burner to rip from.
It's impossible to guarantee making all discs playable in all players. Too many factors. Best you can hope for is the right combination of Media (+ - and brand), Writer and Authoring process for success in the highest % of players.
There are 81 comments for your writer you're considering, with reports on what media has worked best & worst.
You can help the Mods by going to your original post and changing it to "please delete" or something, so they know it was an honest mistake. Only Mods can lock or delete posts.
Now, can you answer my question???There's no place like 127.0.0.1
Originally Posted by Gees
In response to what info you DID provide, I've read posts about the LG as well as about the e80, every posts I can find actually and it was a great number of them. It was from these posts that I was able to get to the info I have on the LG now. Based on what I read, I wanted to ask a simple direct question that would hopefully generate the answer I need to make my decision. Again that is, is there another or better drive than the LG that will read DVD-RAM and is my proposed idea of how to solve my problem reasonable or would I not get enough better results to justify spending the money to buy a pc burner? -
As you can see in my Sig below I have the Panasonic E50 and the LG 4040B. I have used the E50 to burn a movie to RAM and then used the 4040B to transfer the movie the HDD and used TMPEncDVD to author a menu for the movie and burned it to DVD+RW as a test and it worked in all of the players I own:
Panasonic E50
Panasonic RP82
Panasonic RV31
Pioneer DV-414
Relatives Players:
Pioneer DV-333
Sony DVD (Dont know the make) -
You can also use the Toshiba SD-M1712. I use it to transfer movie on dvd-ram I record from my E30 to my pc. It is about $40.
DVD Ram Drive
By gemma-the-husky in forum DVD RippingReplies: 5Last Post: 26th May 2008, 18:49 -
how do i copy DVD RAM discs to pc hard drive (retaining exact file quality)
By mnbvc in forum Authoring (DVD)Replies: 3Last Post: 19th Apr 2008, 17:32 -
dvd drive cant read cd
By d_unbeliever in forum ComputerReplies: 4Last Post: 20th Feb 2008, 00:43 -
Is there way to copy a Dvd realtime with RAM drive like a standalone playr?
By Blumphf in forum DVD RippingReplies: 18Last Post: 25th May 2007, 06:21 -
DVD-RAM corrupted in PC drive?
By AlanL in forum MediaReplies: 6Last Post: 11th May 2007, 11:08
