  1. I download a AVI file via Emule.
    But I cannot play it.
    I view it with avicodec
    It gave me the data below
    File : 703 MB (703 MB), duration: 1:42:59, type: OGG, 1 audio stream(s), quality: 45 %
    Video : 655 MB, 890 Kbps, 29.970 fps, 480*352 (4:3), DX50 = DivXNetworks Divx v5, Unsupported
    Audio : 47 MB, 64 Kbps, 44100 Hz, 2 channels, 0x674F = Ogg Vorbis (mode1), Supported
    What can I do now to play it?
  2. Download and install this:
    K-Lite Codec Pack 2.10f
    Here is the link to this tool in the tools section.
    https://www.videohelp.com/tools?tool=315#comments
    May 2003
    Pal Realm
    Careful with that one: K-Lite Codec Pack
    This codec pack contains everything you need to be able to playback the most popular audio and video formats(DivX, XviD, AC3, WMV, WMA, MP3, MPEG2). Warning! If you install all codecs and filters you may get video playback problem. Only install the ones you need.
    If you're going to recommend that, might be best to send people to the TOOLS- Codec link on this site, so they see the warning, rather than a direct DL link.
    https://www.videohelp.com/tools#Codecs
    ahh - you've added it now :c) I've changed my link to the main Codecs page.
    There's no place like 127.0.0.1
    The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
  4. Careful with that one: K-Lite Codec Pack
    Agree.... DivX 5 is offered by at the DiVX Site and is easy to download and install. I advise to just install the necessary codec instead of that pack.
    I installed divx51bundle.
    But it did not work.
    after I install k-lite,I can play it now.
    Why?
    Theorectically I could play it after divx51bundle...
    Dec 2002
    If you install the K-lite pack then the DivX bundle, then all you can do is re-format your drive, you've hosed yourself.
    Come on people ya'll missed the problem. The 4cc header isn't being recognized. Get the 4cc changer and make it divx/divx and it will play fine. This assumes you've installed the OGG-Vorbis sound pack.
    It didn't regognice the 4cc of DX50 because it's brand new.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
