  1. Hi,
    I was backing up my DVDs to SVCDs with DVD2SVCD.
    Now I'm trying to Back them up to DVDrs but I have a problem.
    I'm using DVD2DVD with CCE 2,5 and scenarist report that the length of CCE file is different from the length DVD2DVD reports in the scenarist script.
    The process finish OK and the DVDr plays with some players (pioneer 545 - blue sky ) but refuse to play on others (pioneer 444 - panasonic RV10).
    I have tested my DVDp (pioneer 444 ) with DVD-r/rw. I had successfully play DVDrs which I had create with dvdecripter, ifoedit and Nero.
    I like DVD2DVD and I prefer to continue using it. I will try to burn the DVDr with recordnow (what is the difference of max and dx).
    Do you think that this will help me ?
    any suggestions ?
    thanks
  2. try burning the dvdimage.dvd with dvddecrypter.
  3. Hi,
    I tryed this and it worked !!!
    I'm using dvddecripter to read and write dvd5 but I never had try this.
