Hi all
i got a big problem in tmpg.
I loose all audio when i convert my wavfile to mp2.
Can anybody help me, as it is driving me crazy!!!!!
The wavfile works fine before converting....
Results 1 to 15 of 15
Then it's most likely isn't a wav after all, since TMPGEnc really loves wav as audio input.
Where does this wav come from?
/Mats -
i extracted it with audiodub and then saved it as a wav
As you understand, this is still no wav file.
A (true) wav for the average movie (1-1.5 hrs) tends to be about 1 GB-ish. If your wav is quite smaller, it most likely is not in wav format, and has to be decoded to wav before it can be used by TMPGEnc.
You can get info on what codec is used for audio compression in VirtualDub: File -> File Information or use GSpot.
/Mats
PS! If you want to change something in a post you've written, use the Edit button! DS -
Edit ok got it.
I think youre right.
My wavefile from 50min vid is only 200mb.
Thanks for the help -
200 MB for 50 mins is almost certainly not a true wav file, at least not with any higher sampling frequency! Check what codec's used as audio encoder in the wav. If it's mp3, then just rename audio.wav to audio.mp3 and convert to wav (CDEx). If it's ac3, you have to run it thru ac3fix between "rename" and "convert".
/Mats -
Hi again.
I found out that it is ac3
I tried to make a full process in virtualdub, but i get an error(could not find decompressor) i download ac3filer but nothing works.
Please HELP
By the way in virualdub audio fileinformation it says unknown tag(2000)
That must be ac3 right???
How do i get virtualdub to recognize the ac3??? -
Try the GoldWave route. (Load AVI in GoldWave, Save wav).
/Mats -
Hey guys.
I got an 800mb wavfile with virtualdubmod, so everthing is ok now.
Thanks for all your help, i really apriciate(i know wrong spelling) it.
no audio on playback tmpg
By devdev in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2011, 12:05 -
jerky tmpg
By devdev in forum Authoring (DVD)Replies: 6Last Post: 12th Aug 2010, 08:14 -
TMPG DVD Author-old version
By Mållgan in forum Authoring (DVD)Replies: 12Last Post: 7th Mar 2010, 16:46 -
tmpg dvd author 1.6 help plz
By nwa in forum Authoring (DVD)Replies: 8Last Post: 6th Jul 2007, 18:59 -
TMPG plus vs. free version
By bellyting in forum Newbie / General discussionsReplies: 2Last Post: 4th Jul 2007, 01:11
