Results 1 to 11 of 11
  1. Member thespook's Avatar
    Aug 2003
    East Coast. UK
    I am very new to this. I cannot get Nero to recognize my Pioneer 106 writer. I rip the movie to my hard drive but when I open up Nero burning rom it will only display for a cd copy not a DVD. The same problem in Nero express, I have tried tellig Nero to find the 106 but no luck.
    I am using Win XP pro.
    Cheers thespook
    May 2003
    Pal Realm
    My only advice (because I don't use Nero) is to go into your original post, hit EDIT button, and change your subject title to reflect your question. Like "Nero does not see Pioneer 106".
    Many very knowledgeable and helpful people skip over those that only say "help" even if you say "please". :c)
    Good luck.
    There's no place like 127.0.0.1
    The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
  3. Is your problem:
    A) Nero sees the Pioneer106, but won't burn DVDs.
    B) Won't see the Pioneer106 at all.
  4. I have a couple of suggestions. First, does your computer see your burner in My Computer? If it does not, then your burner is not set up correctly in your Bios or IDE channel, Mater/Slave etc. Second, do you have all the latest updates applied to your Nero? Your Nero software may not have all the updates it needs to recognize the drive as a DVD burner. Hope this helps.
    Dec 2002
    Nero only sees drives that have been around since our version was released. Nero 5.10.x won't see my NEC 1300. If you crawl around the Nero site, you can find a drive list. You drop that into Nero and it should recognize your drive.
    Alternatives are to install 6.0.13 .
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  6. Member thespook's Avatar
    Aug 2003
    East Coast. UK
    Its only Nero that does not see the 106. I am using v5.10x. I had a look on the nero site but I can't find anything.
    life's a shit sandwich and everydays a bite
  7. Just wondering if the version of nero that you are using has a pull down menu that you can select the dvd burner applications. At first when i started using nero i thought that it would not burn dvd's until i looked at the pull down menu. I'm using version 5.5.10.32 my 106. Worst comes to worst you may have to upgrade to a version that is more compatible with your drive.
    Dec 2002
    Version 6.0.13 recognizes my DVDRW. However, it won't take my 5.5 without charging me for an upgrade I don't want to pay for. So, I quit using Nero and now I use IMG Tools and DVDDecryptor. 1 extra step with classic, but quite painless, and no coasters.
  9. some versions of nero will only work with the drive they shipped with eg if yours came free with say a plaxtor 122 then it is "locked" to only burn on that drive. referred to as an OEM version.
    The electronic components of the power part adopted a lot of Rubycons.
  10. Member thespook's Avatar
    Aug 2003
    East Coast. UK
    Thanks Guys. problem sorted I found the latest upgrade for nero 5.5 and it done the trick. One thing, I have a 106D installed on another computer with nero No probs, this new one is marked up 106RD what's the difference? anybody knows.
  11. Originally Posted by thespook
    The 106RD is an Acer oem Pioneer 106, it's easy enough to flash it back to a genuine Pioneer 106D with a new firmware (at "the firmware page").
