could u please give me the best settings for dr.divx
i want to make a good quality avi file just like the dvd
i have about 30 - 40 minutes dvd vob file and i want to make it smaller like 300mb or less but with a good quality video.
pls if anybody uses this programme and know the best settings for every thing plz tell me
your not going to find many dr.divx users on this forum.divx.com has a forum with a dr.divx section,but i would sugest a better ripping program like gordian knot. http://www.doom9.org/gknot-main3.htm
its the most popular ripping program. -
Yes, probably are fewer users here than elsewhere. But, as with most things, I suspect there is no "best setting" as everything is very dependent on each video and will change from one to the next (amount of scene changes/motion, colors, light/dark scenes, complexity, etc).
Same as with any encoding, try short clips at various settings to see what works best for that particular video.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
You can't ask for DivX settings without more Info:
1) Resolution
2) Framerate
3) Audio type/rate
4) Movie Gendre (talking heads, drama, action).
1 hour of DivX on a CDR can look pretty good. 2 hours of DivX on a CDR look like crap.To Be, Or, Not To Be, That, Is The Gazorgan Plan
Confusion about DivX-Encoding settings
By foxhunter in forum Newbie / General discussionsReplies: 37Last Post: 23rd Jul 2009, 11:26 -
DVD to DivX - settings for better quality
By CodeMaster2008 in forum DVD RippingReplies: 11Last Post: 14th Jul 2009, 03:20 -
Recommended settings for dvd to divx ?
By jimcgr in forum DVD RippingReplies: 6Last Post: 11th Feb 2008, 07:25 -
Dr. DivX subtitle settings
By drstupid in forum Newbie / General discussionsReplies: 1Last Post: 11th Jan 2008, 07:13 -
Configuring settings when converting to AVI (DivX codec)
By firas_hashim in forum Video ConversionReplies: 15Last Post: 24th Jun 2007, 02:21
