  1. Member wulf109's Avatar
    Jul 2002
    What is Quicktime? I've players to download,but in my browsing I've never seen an encoder for quicktime. Can I encode in Quicktime or should I? Is it a format with quality? I'm confused.
  2. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    http://www.apple.com/quicktime/whyqt/
    Perhaps that'll help a little
    It's just another format, such as .avi or .wmv
    There are numerous codecs for it that range greatly in quality.
  3. Quicktime is the player that Apple produces to playback .mov files as well as other formats. It can be downloaded from www.apple.com.
    I'm not 100% sure about the encoding to the '.mov' format so I'll leave that to one of the Mac guys. As to whether or not you want to encode to .mov depends on the purpose of the file. If you wish to put a file up on the web for people to download then it is a viable option however if you want to view it on a TV or have greater compatibility then you make want to look at say encoding the file into MPEG format.
    The quality of ".mov" varies like any other format depending on the bitrate and the encoder themself. If done correctly (look at the movie trailers that come in Quicktime format) then the quality is quite good.
    EDIT: Beaten by a fraction of a second.
  4. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    a.k.a. 4 minutes
  5. Member The village idiot's Avatar
    Apr 2002
    Adrift among the STUPID
    You can buy QuickTime pro if you want to encode QT movies, or you can use some of the other converters/transcoders. EditStudio says you can encode to QT with just the QT player version, but I have never tried it.
    Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
  6. Originally Posted by tgpo
    a.k.a. 4 minutes
    Subtract the time nature was calling and its only a fraction of a second. :P
  7. Originally Posted by wulf109
    Just another sucky MAC implementation of a standard Microsoft product
    Boycott any site that uses it, like most experienced internet users
    Then again, you'll miss most of TGPO's movies :P :P
    Originally Posted by jagabo
