Ok I usually use Dazzle DVD complete since I want an easy way to make DVDs. But this time I need another program or help fixing my problem.The problem is I encode the files with TMPGenc and put them into Dazzle. When the disc is finished it won't play in my DVD player at all.It plays on my computer but the menues aren't there.
So is there another program(or way) as easy to use as dazzle where I can get a lot of shows on one disc?
muggs
"My first computer cost $2,400, had no hard drive, 16K of memory, a 120KB 5" floppy disk, [and] a green monitor"
Gritz-dvdrhelp.com -
The best way for us to help you is to give us a little more information than what you have so far.
Get a little more specific on what the problem is. Is the video choppy, won't run at all? What encoding options are you using with TMPGENc?
Personally, I outgrew DVD Complete fairly quickly and dropped it about 2 weeks into my DVD creating process. I now use DVD-Lab and have zero regrets. -
I am just curious, I have used DVD Complete quite a bit but never heard this one. I assume you make the menus and had no errors when building the DVD in DVD Complete but it just won't play??? Is that correct? Did you use the burning program included with DVD Complete or a external system? Was it a DV from a Camcorder or a DVD you were doing BU on??
http://www.dvd9to5.com/DVD_Complete.htm(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio
why can't I make dvd w several half hour shows dvd architect/sonic-
By rr1 in forum Newbie / General discussionsReplies: 5Last Post: 14th May 2011, 13:28 -
Ulead DVD MovieFactory 6 prob w/using 3.7GB mpg to make DVD
By GSP_87 in forum Authoring (DVD)Replies: 4Last Post: 6th Nov 2009, 05:05 -
Best software (pref freeware) to make a music DVD that will play in a DVD
By Trollheart in forum AudioReplies: 10Last Post: 16th Jul 2009, 16:12 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 07:10 -
I want to make a DVD..
By Nyntendou in forum Authoring (DVD)Replies: 3Last Post: 26th Oct 2007, 12:33
