I've downloaded some quicktime trailers I wanna make mpegs of.
They all got different sizes ofcourse.
The thing is, if I encode them as 480x576 (PAL/25FPS) I get bad AR on some of them.
How do I do to keep it good, to just dynamicly add black top/bottom to keep the AR good?
In tmpgenc, just set the video to "Full Screen (Keep Aspect Ratio)" under [Setting / Advanced / Video Arrange Method]. This will proportionately adjust the frame size until one dimension (the width in this case) spans the desired final size and there should be the regular letterbox bars at top and bottom.
How to play Quicktime with PNG codec on my videoplayer (not quicktime)
By Henkie in forum Software PlayingReplies: 0Last Post: 11th Nov 2011, 03:50 -
Movie Trailers?
By xxnonamexx in forum EditingReplies: 4Last Post: 5th Nov 2011, 14:02 -
Movie Trailers in Quicktime
By skorpinok in forum Newbie / General discussionsReplies: 1Last Post: 25th Aug 2010, 11:39 -
Quicktime player play 5.1 trailers in stereo under vista
By hypercube in forum AudioReplies: 4Last Post: 14th Sep 2008, 05:29 -
In a world... where no trailers will be the same...
By MeDiCo_BrUjO in forum Off topicReplies: 5Last Post: 4th Sep 2008, 21:51
